A Charged Sheet Between Grounded Plates
  • Thread starter Thread starter Xeroxer
    Charged Plates
The problem involves two infinite conducting planes held at zero potential and an infinite sheet with uniform charge between them. Participants are tasked with finding the induced charge density on the grounded planes and the potential at the position of the charged sheet, as well as the force per unit area acting on the sheet.
  • Participants discuss the implications of grounding the plates and the resulting electric field due to the charged sheet. Questions are raised about how the grounded sheets affect the electric field and potential, and the nature of the induced charge density.
Some participants have provided insights into the electric field generated by the charged sheet and the relationship between electric field and potential. There is ongoing exploration of how to calculate the induced charge density and the potential at the sheet's location, with some participants expressing uncertainty about the setup.
Participants note the complexity of the problem due to the off-center position of the charged sheet and the requirement for the potential at the grounded plates to remain zero. There is mention of a diagram that illustrates the configuration, but details are not fully resolved.
Xeroxer
Two infinite conducting planes are held at zero potential at z=-d and z=d. An infinite sheet with uniform charge per unit area σ is interposed between them at an arbitrary point.
a) Find the charge density induced on each grounded plane and the potential at the position of the sheet of charge.
b) Find the force per unit area which acts on the sheet of charge.
C = [itex]\frac{Q}{\varphi}[/itex]
∫[itex]\rho[/itex]a[itex]\varphi[/itex]bd3r = ∫[itex]\rho[/itex]b[itex]\varphi[/itex]ad3r
σ = [itex]\frac{dQ}{dS}[/itex]
There is a picture associated with the problem but all it shows is that the sheet of charge must be off-center. Because both plates are grounded [itex]\varphi[/itex]=0 for both. Charge for both plates are non-zero. The electric field is the gradient of the potential, thus E at the plates and from z>|d| must also equal zero. I'm unclear what the electric field would be inside though. If the sheet was exactly in between the two plates the charge induced on both plates would be equal and have to balance the charge on the sheet so that E remains 0 outside. Offset, like it is I'm unclear how to solve for the induced charge density.
Potential of Plate further away from sheet (P=C-1):
0 = P11Q1+P12Q2+P13Q3
Potential of Plate closest to the sheet:
0 = P21Q1+P22Q2+P23Q3
Potential of the sheet:
[itex]\varphi[/itex] = P31Q1+P32Q2+P33Q3
Capacitance:
Where:
[itex]\varphi[/itex] = P31Q1 + P32Q2 + P33Q3 - (P11Q1 + P12Q2 + P13Q3) - (P21Q1 + P22Q2 + P23Q3)
From here I'm thinking there must be a way to solve for each individual Q in a nice manner, but I'm stuck. Any help would be much appreciated.
I'd have started from the physics - what would the electric field due to an infinite sheet of charge normally be?
What is the effect of adding a grounded sheet of conductor? (the ground provides charges to the conductor to do what to the electric field?)
The electric field from the sheet would be E=[itex]\frac{σ}{2ε0}[/itex]. The grounded sheets means that the potential at each plate will be zero.
E = -∇[itex]\varphi[/itex]
[itex]\varphi[/itex] = -∫E dl
0 = -∫E dl (at each plate)
How does the grounded sheet ensure that the potential at each sheet is zero?
What physically happens?
Presumably you can sketch the electric field for this situation using your existing knowledge of electrostatics?
What does it look like?
I got it. Thanks for the help. In case anyone else stumbles upon it, here is my solution:
The electric field for an infinite plane is
E = [itex]\frac{σ}{2*ε_0}[/itex]
The generalized electric potential is then
[itex]\varphi[/itex] = -∫[itex]\frac{σ}{2*ε_0}[/itex]dx = - [itex]\frac{σ*x}{2*ε_0}[/itex] (where x is distance from plate)
The charge distribution for each plate can be found by determining the potential at each plate
σ1 = -[itex]\frac{σ(d-z)}{2d}[/itex]
σ2 = -[itex]\frac{σ(d+z)}{2d}[/itex]
[itex]\varphi[/itex]Sheet = [itex]\frac{σ(d^2-z^2)}{2dε_0}[/itex]
To find the force just take the negative gradient of [itex]\varphi[/itex]Sheet and times by q.
Well done.
Aside: you'll find equations less painful using LaTeX :)
  • · Replies 31 ·
  • · Replies 26 ·
