How Is Momentum Conserved in a Golf Ball and Clubhead Collision?
  • Thread starter Thread starter davedave
    Hard Momentum
In a collision between a golf ball and a clubhead, the golf ball, weighing 46g, exits at 1.5 times the velocity of the clubhead. To determine the mass of the clubhead, calculations reveal it to be 138g. Additionally, the discussion prompts an analysis of the proportion of the clubhead's initial kinetic energy transferred to the ball. Participants emphasize the importance of showing work for assistance, indicating a focus on learning rather than simply obtaining answers. The conversation highlights the need for proper forum etiquette in academic discussions.
davedave
A 46-g golf ball flies off at 1.5 times the velocity of the clubhead that struck it.
a) Show that the mass of the clubhead was 138g.
b) What proportion of the clubhead's initial kinetic energy was transferred to the ball?
1. Wrong forum, try the homework section.
2. You have to show some of your work before you can expect any help. We're not going to hand you the answers.
Nick said it all.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
