How Does the Kronecker Delta Function as a Substitution Operator?
  • Thread starter Thread starter bossman007
    Delta
bossman007
[PLAIN]http://postimage.org/image/s7m1kohst/ [/PLAIN]
The Kronecker Delta = 1 ; if i=j
The Kronecker Delta = 0 ; i (not equal) j
I have no idea what to do from here, or even if I did this first step right?
[PLAIN]http://postimage.org/image/t3d3u9qg7/ [/PLAIN]
Still no luck on my own :(
Okay so expanding your sum :
\sum_{i=1}^{3}a_iδ_{ij} = a_1δ_{1j} + a_2δ_{2j} + a_3δ_{3j}
Note that the only term which survives is the term a_jδ_{jj} where i=j, but δ_{jj} = 1 as per the Delta Kronecker. So a_jδ_{jj} = a_j
Are you sure that's the question? I feel as if you're missing something. Some important intervals are not mentioned here.
Thats the entire problem...im still confused from ur response, but I feel u gave me a good nudge in the right direction. thx
That's the entire problem...hmmm
I solved it for good, I understand it now. many thanks. The Kronecker Delta has the role of a substitution operator, basically replacing a repeated indice
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
