A packet is dropped from the window
  • Thread starter Thread starter Aladin
    Window
When a packet is dropped from a helicopter moving upward, it initially retains the helicopter's upward velocity, causing it to move upward for a brief moment. This phenomenon occurs because the packet is momentarily stationary relative to the helicopter before gravity and air resistance begin to act on it. Newton's first law explains that an object in motion will remain in motion unless acted upon by an external force, which in this case are gravity and air resistance. The helicopter continues to ascend due to the upward force generated by its blades, while the packet's initial upward motion is a result of its retained velocity. Ultimately, the packet will slow down and begin to fall as these forces take effect.
Aladin
A helicopter is moving with some velocity in upward direction,a packet is dropped from the window of the helicopter.why the packet goes upward after dropping?What will be the velocity of the packet ?is its velocity is same as the helicopter?why,why?please explain.
Initially, the packet moves with the same velocity as the helicopter. Why would you think otherwise?
When you drop an object from a stationary window, there is an instant during which your hand is no longer supporting it, but it has not yet started to fall. (In most real-world instances this moment is vanishingly brief but, in some cartoon situations it can last indeffinately, and largely deoends on how long it takes for the object to notice that it is unsupported.)
If you repeat the same process in a vehicle that is moving upwards, the object still has a tendency to remain "staionary" for an instant, but that means stationary relative to your hand, which means "moving upward" relative to the ground.
Same idea as dropping something inside a train (similar to something in another thread). Although it drops straight down relative to the train, it describes a parabolic path relative to the ground.
Oddly, the OP seems to think that, initially, the packet actually goes up.
Not so odd, since the helicopter is moving upward.
Well,think of Newton's 1st law. The packet already has a velocity and will continue in that constant velocity. There will however, be external forces, air resistance and gravity which will pull it downwards. The reason the helicopter does not fall as well is that there is a force upwards exerted by the helicopter blades, well, making it able to fly in the first place.
I am not understand please give me the reason that why the packet goes upward first.on the other hand the blades of helicopter are pushing air downward direction.then why the packet goes upward?
True. But the air from the blades that pushes the packet down is a force. It CHANGES the velocity, not set the initial velocity. The initial velocity is set by the helicopter's velocity. In other words, it will keep on moving at that velocity since it is already moving upwards in the first place. Of course it will slow down and later fall but that is because of the existence of forces.
