A question from from thermodynamics
  • Thread starter Thread starter aradhya96
    Thermodynamics
The discussion revolves around a thermodynamics problem involving a mercury manometer with unequal arms. The scenario describes a setup where mercury is induced into the manometer, causing it to rise in one arm, and the task is to determine the height of the mercury column in the longer arm. Participants emphasize the importance of attempting the problem independently to enhance understanding, suggesting that clues can be found in the relevant chapter. They also correct terminology, noting that it should be "manometer" instead of "monometer" and "stopcock" instead of "stopclock." The conversation encourages problem-solving and comprehension of manometer principles.
aradhya96
I was doing chapter named kinetic theory of gases from a book. here's the question.
A mercury monometer consists of two unequal arms of equal cross section area 1 cm^2 and lengths 100 cm and 50 cms. The two open ends are sealed with air in the tube at a pressure of 80 cm of mercury. some amount of mercury is now induced in the monometer through the stopclock connected to it. If mercury rises in the short tube to a length 10 cm in steady state, find the length of mercury column rised in the longer tube.
Science news on Phys.org
Welcome to PF;
That's a good problem to do - how are you attempting it? Usually you will find clues in the chapter you just read.
In general you will learn best by attempting the problem - usually badly, but you may surprise yourself, and then we can help you where you get stuck. I know - it's a pain ;)
Some tips: I'm guessing the devices are...
* manometer (not monometer)
* stopcock (not stopclock)
... the problem is checking you understand how a manometer works ...
