A question on vehicle aerodynamics
53 replies · 16K views · last reply
grey said:
my apologies for this impertinence all along...
so i think i was missing this trick...really sorry...
number of passengers= 1 (min weight 70 kg)
weight of vehicle = 160 kg (max)
length = 220-350 cm
width = 120-130 cm
height = 100-130 cm
wheel base= 120 cm (min)
axle length = 100 cm (front, min), 80 cm (rear, min)
wheel rim dia (16-17 inches)
i think these are the main things
power source = there's a choice, but we have decided on IC engine with gasoline most prolly our fuel
hybrid is an option we are considering but that depends on the weight-power ratio, iff we can squeeze into the limits
obviously, i can't give you the power of the engine coz that i think should be worked out after we know what we are up against (in terms of how much to move, and drag)
the rest you can see in the rules (for UrbanConcept) in the site
the event is shell eco marathon asia
http://www.shell.com/home/content/eco-marathon-en/asia/welcome_sem_asia.html
obviously, i reread Cyrus' last post again...so much data regarding the constraints i have posted. regarding looking up research papers, i am not sure as to what to look for...design? our key aim is to reduce drag (my aim is to keep the co-efficient of drag x frontal area <0.1) and minimise weight (that obviously depends on materials, surface area, power system etc, which we can't get a figure until the design of the chassis is done)
if anything, i have missed, do tell so i post it
I'm glad to see you listened to my advice. Now you are on a path for success. Find yourself a copy of Fundamentals of Vehicle Dynamics by T.D. Gillespie. I will scan the refrences in the chapter on aerodynamics for you and post it later so you have a jumping off point in terms of your literary search, which is what you need to do right away. And, be INTENSIVE in this search for information. If you don't do this, you will waste your time reinventing the wheel. At best, you can find an existing design you like and simply use it. You can justify your choice based on the research you did, and I think that is just as impressive as coming up with a unique idea because it shows careful consideration and respect for research already done in this field. As for your statement:
"my aim is to keep the co-efficient of drag x frontal area <0.1"​
The value of [tex]C_D \times S[/tex] is called the wetted area (or also the wet plate area). Where [tex]C_D[/tex] is the coefficient of drag and [tex]S[/tex] is the reference area.
Grey
Thanks for the great answer. No need to apologize. Most of us start a conversation with something in mind and often leave that out until later.
The Shell event (and urban concept category) has been run for years. After a while the top winning teams converge on one or two optimal solutions to the problem (rules). Concentrate on the top six teams over SEVERAL years and learn as much as possible from each of their experiences and especially their changes in design. Make charts tracking changes and competition results.
Use these prior experiences and rules to establish minimums and maximums. This will give you the basic boundaries within which you will be creating your design.
Also note Rules Article 53 Visibility. The driver seating and viewing position will establish one of the basic outer parameters for your vehicle shape and drag coefficient. You will want the driver to lay down as far as possible while wearing the helmet and safely driving the vehicle to minimize frontal area.
Note the mirrors rule. Oversized and poorly designed mirrors and attachments can cause a surprisingly large amount of drag.
Explore wheel fans to manage turbulence and vortices created by the wheels and tires. Use NACA vent openings for any required ducts (example: radiator cooling).
Consider strategy. I don't see any minimum speed requirements, no stop-and-go braking, or slolom (driving a weaving pattern through obstacles) either. Write to race authorities and get this clear before going too far on your design efforts. Design your vehicle for its optimum efficient operating range and the actual running in this event. This is a fuel efficiency event. Design to win.
As a basic consideration, complete your vehicle at least three months prior to the event. Build in several very ACTIVE months work before the event with the basic car fully completed. Driving (practice, practice, practice), live testing (roll down, ink testing, streamers), and time to make adjustments/changes to the design (spoilers, foils, air dams, streamlining undercarriage) can make as much difference to drag and final race results as an equal amount of time adjusting designs in software or drawing programs.
You should get a copy of the book "The Leading Edge: Aerodynamic Design of Ultra-streamlined Land Vehicles" by Goro Tamai, Robert Bentley Publishers, ISBN 0-8376-0860-0, copyright 1999. Corrections available on the publishers web site.
Goro Tamai was an Massachusetts Institute of Technology (MIT) engineering student that was the aerodynamicist for MIT's solar racing, and Tour de Sol commuter cars. He went on to win the Young SAE Engineer of the year award and work for General Motors designing among others the "Precept" concept car. The book's main focus is solar continental racers but it covers aerodynamic design for highly efficient competition cars as well. He walks through all the basic questions an aero designer considers in automobile efficiency, shows his calculations, shows real world testing procedures, and explains how to apply it to your project. It is an outstanding resource that is technical, solidly grounded, understandable, and immediately applicable. https://www.amazon.com/dp/0837608600/?tag=pfamazon01-20
This book is a great source for your project. Please note that most aero books and engineering rules of thumb are NOT for wheeled ground vehicles. And the few that are are usually written for high speed (lots of fuel) racing.
Ask any further questions, and keep us up to date as you go forward.
Cyrus,
I have got hold of the book...studying has commenced
PF Mike,
thanks again...just to clear it up a little
1.I don't think drivers are allowed to lay down
2. minimum speed. Minimun average speed for 6 laps of 2.706 km track (16.236 km) is given to be (in the facebook group of this event) 30 km/h...this includes some stops (3 stops of 10 secs each last time)
Article 45: Definition said:
One particular feature of this group is that vehicles competing in this group will require "stop and go" driving
there are no obstacles though
will try to get data from last years' races
will try to get those books too...thanks!:-)
koenigsegg ccx isn't teardrop shaped and it has a drag coefficient of 0.3
Its never going to win a fuel endurance race though is it...
0.3 may be fairly good for a road going car but doesn't cut the mustard for ultra low drag racing.
But it makes up for it in cool points ;)
That doesn't mean anything...it's the wetted area that matters if you want to compare two cars. I could define the reference area a mile wide for a mini van and have a drag coefficient of 0.000000000000000000000000007.
The wetted area is just the frontal area of the car isn't it? So to figure drag you would use
Cd X A^2?
Here is a link to a car that VW is working on, most definatly teardrop shaped
http://www.ultimatecarpage.com/car/1316/Volkswagen-1-Litre.html
Why the frig would you do that? You COULD define the area as that but you'd be utterly stupid to as it tells you nothing useful. Thats like saying I'm going to work out the Reynods number for a flow over a wing and define the characterisitc length as the diameter of the earth. Also say you've calculated your Cd empirically fby finding the drag force and then calcualting Cd.
And of course it means something Cd is how you compare drag between the shape of cars to take out the annoying variables like area and speed, its nondimensional for a bloody reason.
He was making a statement that the drag coeffient for a CCX is 0.3... which it is. Just like the Cd for a Lotus 7 is 0.7. And just like the Cd for an F1 car varied according to how much downforce its set to. They are all calcualted in a standard way. So there is bugger all wrong with his statement.
Can you just take a step back and stop yourself from making stupid posts simply for something to do. I wouldn't mind you being argumentative if you contibuted something remotely useful to furthering the discussion.
More to the point, what on Earth was the point of your post, how was it relevant?
EDIT: And don't bother waving your hands and trying to justify yourself by saying CdA is more important than Cd, because it isnt. If you are going for that mentality you may as well just throw everything in and talk about Fd. He was referring to the shape only.
Please go back and re-read my post. The point is that if the cars do not have the same frontal area it is meaningless to directly compare the drag coefficient.
Provided they have the same reference area, then yes. Is there a standard refernce area used in automotive aerodynamics?
I have reported this portion of your post.
PS, do you notice how the tabulated values here are wetted parameters?
http://en.wikipedia.org/wiki/Automobile_drag_coefficient
I.e., [tex]C_D A[/tex].
While designers pay attention to the overall shape of the automobile, they also bear in mind that reducing the frontal area of the shape helps reduce the drag. The combination of drag coefficient and area is CdA (or CxA), a multiplication of the Cd value by the area.
In aerodynamics, the product of some reference area (such as cross-sectional area, total surface area, or similar) and the drag coefficient is called drag area. In 2003, Car and Driver adapted this metric and adopted it as a more intuitive way to compare the aerodynamic efficiency of various automobiles. Average full-size passenger cars have a drag area of roughly 8.5 ft² (.79 m²). Reported drag area ranges from the 1999 Honda Insight at 5.1 ft² (.47 m²) to the 2003 Hummer H2 at 26.3 ft² (2.44 m²). The drag area of a bicycle is also in the range of 6.5-7.5 ft².[16]
Also, don't put words in my mouth:
Please read page 307, notce anything special about the y-axis?
http://books.google.com/books?id=nM...sult&resnum=4#v=onepage&q=wetted area&f=false
This is why you can't add the contributions of drag in coefficient form from each part of the car unless they all have the same reference area. Each car is going to have a different reference area, which is typically the frontal area of the car. Hence, why you can't simply compare one Cd value to another and have it be meaningful. This is why saying things like 'car X has a Cd of such and such" is as meaningless as boasting about your car having 900HP, and failing to mention it weighs as much as a big rig.
No, this is where your problem lies. Cd is not defined the way it is to "take out the annoying variables like area and speed". Cd is a nondimensional parameter for a bloody reason you failed to mention, similitude. People don't put full size cars inside wind tunnels because its very, very expensive. Instead, they put scale models. In order to put a scale model, you must have dynamic similitude, which occurs through the buckingham-Pi theorem of nondimensionalization. You can then SCALE UP the value of Cd from the model to the full size production car by scaling the REFERENCE AREA.
This does not mean Cd is a valid metric for comparison of cars. The wetted area is a better metric.
My paragraph above explains this in detail.
Hmm ok I've decided I am going to have to be careful trying to explain the reasoning on with this one as you do have me worried I am wrong. It's been a while since I've had to do any aero work.
As we arent comparing cars directly only the shapes. And although you need the same reference area to directly compare shapes. Cd gives a better indication of how good the shape is when you know nothing about the car than CdA. CdA is a better metric if you want to compare cars themselves and not just the geometry.
You come from an aerospace background don't you?. As cars are bluff bodies comparison methods differ slightly, wetted area doesn't really mean much if the flow has separated and the drag is coming from the pressure. We always use frontal area for a car. (unless you are using wetted area to mean frontal area)
The reason for this is that CdA can give misleading ideas when talking about bluff bodies rather than spteamlined. A low Cd car with a high CSA can give a higher CdA when compared to a high Cd car with a low CSA.
For example:
Ok we have a small family hatchback shaped car with a drag coefficient of 0.3 with a frontal area of 0.5m^2
We have much larger modern GT car with a drag coefficient of 0.25. With a frontal area of 0.7m^2.
The CdA for both is:
Hatch: 0.15 m^2
Sports: 0.175 m^2
Now if we knew nothing about the Cd of these cars, but wanted to pick one of the shapes we could have to conclude the hatchback is better on data availalbe when the GT car produces more drag simply because it is bigger doesn't lead to a good comparison as if the Gt car were the same size it would give a lower CdA. Basically the shape of the GT car goes through the air better than the hatchback.
As you stated Cd is there for simlitude, which allows scale models to be used. Imagine two cars of different CSA are just scales models of the car that you want.
We take the CdA, divide by the CSA of the acutal car to get the Cd then multiply it by the new CSA of the car we are going to build. Why not just cut the step to comparing a similar 'wetted area' and just compare the Cd values. Obviously this only holds for similar conditions (same Re same Mach etc etc).
Now when you are dealing with streamlined bodies such as planes/wings. Wetted area is more useful because the flow stays attached and the majority of the drag comes from skin friction which is area dependent. Which is why I like the fact you used a helecopter aerodynamics book to prove a point about car aero. I know in general aero is aero, but the method about comparing cars always tends to use Cd because the flow seperates.
One textbook example I can think of that demonstrates this is you have a small diameter circe and a large aerofoil i think the characteristic length of the aerofiol was 10x that of the circe (i'll try to find this example from my books and fill in the details)
They both have the same drag force (so the same CdA as they were tested under the same conditions) but the streamlined aerofoil has the lower Cd.
Now its obvious that when you scale the aerofoil down to the same charactersic length as the circle it will have a much lower drag.I'd like to apologive for the tone of my last post, it was hastily typed. Dont get me wrong Cyrus I like you and your direct approach, but sometimes you piss me off with needlessly condecending or combative posts. I wouldn't mind if they were wrong and talking bollocks but the guys post was clearly anecdotal. I pointed out that it didnt matter and he used the phrase 'cool points', that more than anything else shows he wasnt tryin to make a serious point.
Hmmm - back when I studied the fundamentals of fluid dynamics, we looked at both frontal area and surface area and we had to calculate the normal dynamic force and friction (shear) force. Then we'd have to consider flow separation, which put a static force on an object due to the differential pressure between front and back.
Of course, a car is designed for utility and operation/environment. The utilities of a race car, sports car and family passenger car are all different, and so are their environments and operation. The utility (function) is just one of the constraints with which a designer must deal.
And there is the coolness factor for sports car and family car. A race car just needs to be fast, reliable and safe at the higher speeds at which it performs, and the designer isn't constrained by the comfort or appeal of the driver.
When I looked at the ultimatecarpage site, the banner at the top had a picture of couple of the Gulf Porsche 917's from back in the early 70's. Fantastic car, but it was quite uncomfortable for the driver. The space for the driver was minimized to reduce frontal area. Visibility to the rear was a problem too, because external rear-view mirrors would project into the airflow and the rear window was small. The only time one needed it was when someone was trying to pass (not too often) or the driver was passing another car (most of the time).
http://www.khulsey.com/stockphotography/porsche_917k_le-mans.jpeg
xxChrisxx said:
Cyrus we arent comparing cars directly only the shapes. And although you need the same reference area to directly compare shapes. Cd gives a better indication of how good the shape is when you know nothing about the car than CdA. CdA is a better metric if you want to compare cars themselves and not just the geometry.
If you are going to compare cars on nothing but shape, then you need to make sure both cars have the same frontal area for a direct comparison of Cd. Otherwise, CdA is the only thing that make sense as a comparison.
You have also got to be really careful Cyrus, because you blatantly come from an aerospace background and are used to dealign with streamlined bodies. Car's as you probably konw are bluff bodies. This is why comparison methods differe slightly, wetted area doesn't really mean much if the flow has separated and the drag is coming from the pressure.
The problem is that the frontal area is not a constant for every car.
I don't know what "CSA" stands for: I think you mean frontal area for CSA. We call this S in aerodynamic standards. If that's the case, then what you wrote in the second sentence is exactly my point. The influence of area cannot be ignored for exactly that reason. When comparing two cars a given dynamic pressure, q, I care about which one has a higher drag force because it will require more power. CdA tells me this, Cd does not. Cd only helps for similitude of scale models.
For example:
Hatch: 0.15 m^2
Sports: 0.175 m^2
Now if we knew nothing about the Cd of these cars, but wanted to pick one of the shapes we could have to conclude the hatchback is better when the GT car produces more drag simply because it is bigger doesn't lead to a good comparison as if the Gt car were the same size it would give a lower CdA. Basically the shape of the GT car goes through the air better than the hatchback.
No, it says that the Hatch does go through the air better at a given speed than the GT. The hatchback will absolutely require less power to stay at a fixed speed. If you want to compare the two cars at a purely geometric standpoint in terms of the aerodynamics, give them both the same refernence area. Then you can compare the Cd. In fact, this is what you are doing implicitly in your argument of "just compare Cd"!
Eg above. We know that out frontal area of the car is going to be 0.3m^2 for example.
CAR 1:CdA 0.15
CAR 2:CdA 0.175
Ok so we divide by the current CSA and times by new CSA.
CAR 1: 0.15*(0.3/0.5) = 0.09
CAR 2: 0.175*(0.3/0.7) = 0.075
As the above is simply the Cd multiplied by the area we want. Why not just cut the step to comparing a similar 'wetted area' and just compare the Cd values. Obviously this only holds for similar conditions (same Re same Mach etc etc).
Because when you "cut the step" that is an assumption of having the same reference area value for both design shapes.
Cd is a funcion of Re and Ma and flow direction. Under the same conditions the Cd will be the same. So i'll repeat what I said above so you don't miss it. "Obviously this only holds for similar conditions (same Re same Mach etc etc)".
Yes, that needs to be held constant, but that isn't the issue here.
Of course when you scale both shaped down to the area you want the one with the lowe rvalue od Cd is the one that gives the lower drag. This is why at the start of designs, when you know the rough size of the car you want but want to focus totally on the shape its more useful to compare Cd values of other cars NOT CdA.
Exactly, because they both have the same area!
Attached or unattached flow doesn't matter, that is accounted for in the value of Cd. Helicopters are by no means streamlined, they are a highly unsteady aerodynamic environment due to the rotors. Any unsteadiness is captured by time varying aperiodic terms inside of Cd, i.e Cd = Cd(Re,Ma, time, and other explanitory variables).
I'll leave with this. For cars in the wind tunnel, you can cause them to have side slip angle and get a side force. What is interesting is that you can return the car back to centerline of the wind tunnel, but you will still measure a strong side force despite no yaw angle. A flow condition occurs where the car starts sheading a vortex that doesn't go away when the car gets back to center. Very counter-intuitive.
I will also note: I am glad the OP stated his car has a targed wetted area < 0.1 for the competition.
Quote:[People don't put full size cars inside wind tunnels because its very, very expensive. Instead, they put scale models. In order to put a scale model, you must have dynamic similitude, which occurs through the buckingham-Pi theorem of nondimensionalization. You can then SCALE UP the value of Cd from the model to the full size production car by scaling the REFERENCE AREA.]
People don't put full size cars in wind tunnels? They most certainly do! There are some things that just don's scale up well, what do you think the apparent air density is for a 1/16th scale model is compared to a full size car. Air is not going to behave the same way on a model as it will on a full size vehicle. vortexes may not appear on a smaller model, It is damn near impossible to account for air that may be flowing THROUGH the car in areas like the radiator, under bumpers, undercarriage, etc. Another reason they do it is to take measurements of road noise and drafts in the vehicle. Please do a little research before you make such a false statement, people are on this forum are trying to understand new concepts and they don't need to be misled. Here are some links I turned up in about 60s of googling.
http://www.gm.com/experience/autoshows-events/racing/technology/aerodynamics/index.jsp
http://exoticcars.about.com/od/guidedtours/ig/Mercedes-Benz-SLR-McLaren/SLR-McLaren-wind-tunnel.htm
http://trucks.about.com/od/2007fordtrucks/ig/2009-Ford-F-150-Truck-Pictures/09-Ford-F-150-Wind-Tunnel-Test.htm
http://www.carbodydesign.com/gallery/2009/05/14-volkswagen-polo/22/
I should have said, don't always put a full size car in a wind tunnel, that was a bit careless on my part. Don't lecture me on air density about scale cars when I was in a wind tunnel doing testing and saw a scale car sitting there from previous testing. It was a ford tarus. In fact, back in the 90s GM did so much testing they had their own private section of the tunnel. Road noise is from the RMS signal of the vibrations on the road. That's not something a wind tunnel tells you.
Ken not to bash you mate but you are wrong about the air not acting the same way.
If the people just put a scale model in a flow without changing it then, yes it wouldn't behave the same way.
In scale wind tunnel tests they use simlitude, (look up reynolds and mach numbers) to ensure that it does act in the same way as on a full sized vehichle.
This is the reason why people can use water tunnels to test (air)flow over cars.
Google doesn't give you all the answers I am afraid.
In model testing though; doesn't the air appear much more dense than it would with a full size vehicle? I know you could scale up the drag, but it seems to me that you would be missing out on quite a bit of important info by just using a model because there is a possibility that things like turbulance simply won't form on a smaller model because of the much greater apparent density of the air. That's just my reasoning though, I could be wrong I am not an expert.
Like I said, all that matters is that the nondimensional coefficients are the same. If thet is true the fluid will act in exactly the same way. All the information is there.
Now obviously sometihngs may be missed purely because of the size. All the phenomena are there, but if you are interested in a specific thing such as a vortex (that may be too small to capture by probes/smoke+camera) they sometimes run overscale models. So the model is X times larger than the actial thing.
A few things need to be cleared up here.
[1] You were absolutely correct about full size testing. Some points though: the characterization of air through the engine scoops, moon roof, etc are very much final stage design items. It is WAYYYYYYYYYYYY to expensive to keep putting in new full size cars with different designs on them for something like engine intake scoops during the initial design of the car. The small models (and now CFD) are used for major body changes in the car. Once a more-or-less finalized design is reached a prototype is made. This full size prototype is VERY EXPENSIVE. That's why people use models first. Then the kinks are worked out in the full size tunnels you linked to earlier.
[2] The use of a small car is possible through similitude, which means (in the case of wind tunnels that have air as a working fluid), you need to make a scale model of the car. You can get away with this (pretty well) because the Reynolds dependency is relatively flat over a large range. It won't be 99% right, but it won't be very horrible. It will be pretty darn close. But that doesn't matter for a car! You can always put it in the full size wind tunnel when you make the actual prototype! Notice how you CANT do the same thing for an airplane though, which makes it much more of a challenge in terms of interpreting the data from a scale model. Provided the Reynolds number stays similar, the transition points and boundary layer should stay the same. Thats the entire point of Reynolds dependencies in the flow.
