A question relating to electricity
  • Thread starter Thread starter MAHBRAINHURTS
    Electricity
The discussion revolves around calculating the speed of a moving electron as it approaches a charged ring, focusing on the complexities of acceleration and energy conservation. Participants suggest using conservation of energy principles, noting that the initial energy should equal the final energy, which includes a velocity term. It is emphasized that the problem can be simplified by applying kinematics or energy conservation rather than overcomplicating it with integrals. Questions about the role of radiation and electric potential energy are raised, highlighting the need to consider the electric field's impact on the electron's motion. Overall, the consensus is that the problem can be approached more straightforwardly than initially perceived.
MAHBRAINHURTS
Hi guys, new to the forum so I apologize if I post in the wrong place or something. I'm in an engineering physics II class right now and honestly this material is so hard for me I feel completely overwhelmed (yet sadly I can't get my degree without it). I'm doing some problems right now and have a question on one.
In one problem I'm asked to calculate the speed of a moving electron as it moves towards a charged ring at the point where it reaches the ring, the object is at rest initially and moves towards the ring from some distance. My question with this one is how I take into change in acceleration as it moves closer (if there is an increase in acceleration) to solve it. I guess this is more of a simple kinematics problem, since I can mostly figure out the charge part, but I have a feeling it involves taking an integral of the velocity, and I think I'm making it more complicated than it is.
I might have more questions or find my own solutions so I will edit this thread as needed.
EDIT: I guess this should be moved to the homework forum, sorry. :(
Yes, you are right - on two counts. It could be solved by using an integral and some kinematics, and you are making it more complicated than it is. :)
Consider conservation of energy... the initial energy should equal the final energy. The energy contains a velocity term which could presumably be solved for.
Many of these types of physics problems can be solved by kinematics or conservation of energy. When you can, appeal to conservation - its usually easier.
Where does the radiation by the charge fit into the problem? Is it really just simple kinematics?
If the electron is initially at rest don't you just need to find the electric potential energy at some distance due to the E field from the ring? This is not a terribly horrible thing. If the electron then reaches the middle of the ring (hopefully), then its all kinetic (no Efield in the very center) and v for the electron can be solved for.
The electron would then move past the ring until it reached the same initial position away from the ring but on the other side, and then return. Or am I making this way too simple?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
