A rock is THROWN downward. What was the initial height?
The problem involves a rock thrown downward from an unknown height with an initial speed of 27 m/s, striking the ground after 7.1 seconds. The context is kinematics, specifically dealing with motion under gravity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of the equation for displacement and express uncertainty about the correct setup due to the downward throw. There are questions regarding the handling of signs in the calculations and the implications of the initial velocity being downward.
Some participants have attempted calculations but have encountered issues with the results, suggesting that there may be confusion regarding the application of the equation and the correct sign conventions. Guidance has been offered regarding the importance of sign usage and the format required by the web application.
Participants note that the web application used for checking answers may have specific requirements for formatting, significant figures, and units, which could affect the correctness of their submissions.
AVReidy
A rock is thrown downward from an unknown height above the ground with an initial speed
of 27 m/s. It strikes the ground 7.1 s later. Determine the initial height of the rock above the ground. The acceleration of gravity is 9.8 m/s2. Answer in units of m.
[itex]\Delta[/itex]x = vit + 1/2 at2
I'm not sure if this equation is correct, first of all, but it has all of the variables given in the problem. I don't know how to deal with the fact that it's thrown down, but I thought the vi would take care of it.
We have acceleration, initial velocity, and time, and the equation solves for displacement. What am I doing wrong? How should this problem be set up differently and why?
Thank you very much.
It will.
Looks good so far. What's preventing you from solving it?
Be careful with signs.
We're using a web application that checks the answers for us, and I got it wrong when I entered what I got. I'll try again with the same method, though. I may have messed up the signs, but I also feel like this problem takes more than just plugging into an equation.
A lot of times web applications have to have a specific format for both the values (including proper use of significant figures and rounding) as well as the units.
In order to know where you went wrong, we need to know what values you plugged in and what was your result.
(Regardless of the sign convention you use in solving the problem, the answer that they want will be positive.)
I solved this again and got -55.309. This is not correct, and neither is its absolute value.
I'm confident in my 4th grade order of operations ability, so the problem probably lies in how I set this up. Here is what I solved:
[itex]\Delta[/itex]x = 27(7.1) + 1/2(-9.8)(7.1)2
[itex]\Delta[/itex]x = -55.309 Incorrect
Since the rock is thrown downward, what must be the sign of its initial velocity?
Thought about that but hesitated to try it. The absolute value of the solution was correct! Thank you very much, Doc Al. I'm still getting used to watching my signs.
That's a sticking point for a lot of folks when they first start getting into the equations of motion. Just remember that g = -9.8m/s2 only if you define the upward direction to be positive, so in your example, since you throw it downward, the initial velocity is negative.
  • · Replies 25 ·
