A rocket moving vertically -- Find the cosmonaut's weight
  • Thread starter Thread starter inv4lid
    Rocket Weight
The discussion revolves around calculating the weight of a cosmonaut in a rocket accelerating vertically at 22 m/s², with a mass of 90 kg. The relevant equation used is N = m(a + g), leading to a calculated weight of 2880 N. Participants clarify the distinction between solving a problem and recognizing the solution, emphasizing the importance of understanding the result. The conversation highlights the need for confidence in problem-solving, even when initial uncertainty is expressed. Ultimately, the cosmonaut's weight was successfully determined through the application of the correct physics principles.
inv4lid
A rocket during launch from the Earth's surface moves vertically with an acceleration of 22m / s ^ 2. Find the cosmonaut's weight inside the cabin if his mass is 90kg.
The problem belongs to "Elasticity. Moving under the action of elastic force" chapter.
General gravity relating to man = 900N;
N - G = ma?
N = m(a+g)
N = 90*(22+10) = 2880 N
No idea currently, trying to solve[/B]
N - G = ma?
N = m(a+g)
What the definition of weight?
Likes inv4lid
What do you mean ”no idea”? You essentially solved it.
Likes inv4lid
Just got it, ty anyway
There's solving a problem and knowing you've solved it!
Likes inv4lid
I think the two are the same (as long as you got it right). Hence the addition of the ”essentially” - the remaining step being to realize that what was computed was the sought quantity.
Likes inv4lid
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
