A shaft of light pass through the prism
A shaft of light passing through a prism with refracting angle θ and refractive index n experiences a deviation angle α. The discussion centers on demonstrating that α is minimized when the light passes symmetrically through the prism, meaning the internal path is parallel to the unused face of the prism. This symmetry implies that the angles of refraction at both faces of the prism are equal and opposite. To prove this, one must relate the angles using the properties of triangles and set the derivative of the deflection angle with respect to the angles equal to zero. Ultimately, the key conclusion is that symmetrical passage through the prism results in the least deviation angle α.
thee
A shaft of light passes through a prism with refracting angle \theta and refractive index n. Let \alpha be the deviation angle of the shaft. Demonstrate that if the shaft of light passes through the prism symetrically the angle \alpha is the least?
The least in regards to what?
-Dan
I suppose that \beta is the refracting angle
I think that it try to proove that \beta is equal to \theta angle \alpha will become the least.
"passes through symmetrically" means that the path inside the prism
is parallel to the face of the prism that isn't used as a window ...
that is, theta_glass on face 2 = - theta_glass on face 1.
You'll probably want to assume an "apex" angle for the prism
and recall that the interior angles in a triangle sum to 180,
to relate the theta_glass on face 2 to the theta_glass on face 1.
With the deflection angle as a function of theta_glass, set the derivitive =0.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
