A silly question about gravitational waves
Gravitational waves, predicted by General Relativity, are ripples in spacetime that can cause slight distortions in the fabric of space. If a gravitational wave were to pass through a person standing on Earth, the effect would be so minuscule—on the order of 10^-20—that it would be imperceptible. Theoretical models suggest that as these waves pass through a set of test particles, they would stretch and compress them, but the amplitude is too weak for any human to feel. Even in microgravity, the experience would likely be undetectable. Overall, gravitational waves are currently only indirectly measured, with no direct detection of their effects on human observers.
Light Bearer
Alright, so I have been reading about gravitational waves and have a silly question to ask. Suppose, hypothetically, under the right conditions you were standing somewhere on the surface of the Earth and a gravitational wave were to pass through the area of space you were occupying...would you "feel" it? Or rather than standing, suppose you were falling and a gravitational wave passed through that area of space, would you "feel" it? Would you momentarily fall at a faster/slower rate if that were to happen? OR suppose you were in a microgravity environment...if you could feel it, what would it feel like?
Thanks in advance for any responses.
It's happening to you right now thanks to the moon. The tides on Earth occur due to the moon's gravitational effect on the Earth, so the moon's gravity is affecting you right now. It isn't strong enough for you to notice, but it's there. If there were a gravitational effect, other than the Earth's gravity, that was acting on you strongly enough for you to notice, I believe that would have catastrophic effects on the Earth, but I'm not saying that with any authority.
The question was about gravitational waves, not just the moon's gravitational effect. While gravitational waves are predicted by General Relativity, none have ever been detected.
When gravitational waves pass by a congruence of test particles, their effect is to shear and expand the congruence. The usual illustration is to imagine a circular ring of test particles; a gravitational wave that passes by will "stretch" the ring into an ellipse whose major and minor axes will vary sinusoidally as the wave passes by. The thing is that gravitational waves in the linearized approximation are very weak in amplitude. It is quite difficult to directly detect them as noted by Halls but they have been indirectly measured.
Gravitational waves are ripples in spacetime. The effect of a gravitational wave passing over you can be illustrated by considering a ring of "test particles" in space. Suppose this ring is initially perfectly circular. As a gravitational wave passes through the point where the ring is, the ring gets stretched into an ellipse, with the long axis alternating between two orthogonal directions. It oscillates between these two states.
Code:
        O O
      O     O
      O     O
      O     O
        O O
stretched vertically   O  O  O
O           O
O           O
   O  O  O
stretched horizontally
Something like that. I suspect that you would feel absolutely nothing at all, because, from a typical astrophysical source, the expected amplitude of the gravitational waves, as quantified by the strain (fractional change in length) is expected to be something like 10-20. Don't quote me on the number -- I just remember that it is something ridiculously small like that.
Good point ... I did kind of slide right by that didn't I ? :rolleyes:
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
