Electric Current in Moving Plate Capacitor with Velocity 6 m/s and U=600 V
  • Thread starter Thread starter Noirro
    Capacitor
The discussion focuses on calculating the electric current in a moving plate capacitor connected to a 600 V source, with one electrode moving at 6 m/s. The participants explore the relationship between capacitance, charge, and current, emphasizing that the current is not constant due to the changing distance between the plates. A key point raised is the need to express the current as a function of time, particularly at t=0. The conversation highlights the importance of using the complete equation for current, which involves the time derivative of the product of capacitance and voltage. Understanding these dynamics is crucial for accurately determining the current in this scenario.
Noirro
Thin parallel plate capacitor is connected to a U=600 V current source. Find the electric current flowing in the circuit if one of the electrodes is pulled at v=6 m/s velocity. The electrodes are square (l=10 cm), the distance between them is d=1 mm.
C=ε0\frac{A}{d+vt}, C=\frac{q}{U}, I=\frac{dq}{dt}
I tried finding the current by first expressing q from those capacitor equations and plugging it into the dq/dt equation, but there is still time t left. I am not sure if the answer depends on time or is it possible to find some constant value of I?
No, the current is not constant. Find the time dependence of the current, and the current at t=0.
ehild
ehild
OK thanks!
I assume you mean a voltage source.
Hint: i = C dV/dt is not the complete story.
The complete story is i = d/dt (CV).
