A typical motion question (am I correct?)
  • Thread starter Thread starter Hadjiev
    Motion
The discussion revolves around a physics problem involving a helicopter rescuing a boy from a flooded street. The boy is initially 6.4 m above the ground when the helicopter accelerates upward at 0.2 m/s² for 8 seconds before the cable snaps. The calculations confirm that the boy's initial velocity at the moment of the cable snapping is 1.6 m/s, and he falls a total distance of 6.4 m. After applying the kinematic equation, the final speed of the boy upon landing is calculated to be 11.31 m/s, which converts to 41 km/h. The participants confirm the logic and calculations regarding the boy's motion and velocity.
Hadjiev
Hey, I was wondering if someone could check my answer for this question:
A helicopter is rescuing a boy from a flooded street. Hovering 20 m in the air, a cable is lowered to the child. After it is attached, the helicopter begins to accelerate upwards at 0.2 m/s^2. Eight seconds later, the rope snaps and the child plunges to the ground. How fast (in km/h) was the child traveling when he landed?
Helicopter:
a = 0.2m/s^2
t = 8s
v1 = 0 (I figured since he is hovering)
Boy:
v1 =
d =
a = 9.8m/s^2
I started by calculating the overall distance the helicopter traveled; it came out to 6.4 m, which makes it 26.4 m in the air. The boy must then be 6.4 m off the ground, and thus his fall is a total of 6.4 m.
Then I calculated the final speed of the helicopter. I figured that the final speed of the helicopter should be the initial speed of the boy. This came out to 1.6m/s
At this point I have the distance of the boy's fall, his acceleration, and his initial velocity (it turned out to be negative, due to direction).
I subbed in acc, v1, and d into v2^2 = v1^2 + 2ad and got an answer of 11.31 m/s, which ends up being 41 km/h.
Is my logic correct? Thanks in advance,
Nicholas
What is v1 in the equation - v2^2 = v1^2 + 2ad.
Your logic regarding the altitude of 6.4 m and the boys velocity 1.6 m/s is correct.
At the point the cable breaks, the boys begins to decelerate, from 1.6 m/s until he stops, V=0, at which point he achieves maximum altitude. Then the boy accelerates downward to the ground.
Ack! I forgot about the upward motion. Thanks Astronuc.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
