A +'ve charge Q is fixed to the origin. A -'ve charge 9Q
  • Thread starter Thread starter abm77
    Charge Origin
A positive charge Q is fixed at the origin, while a negative charge of magnitude 9Q is positioned along the positive x-axis at a distance d. To find a point where a small positive test charge q experiences zero net electrical force, one must consider the forces acting on q from both charges. The test charge will experience a repulsive force from Q and an attractive force from -9Q, and these forces must sum to zero for equilibrium. The discussion emphasizes the importance of vector addition and the relative magnitudes of the charges, suggesting that the specific values are not necessary for determining the equilibrium position. Understanding the net force as the sum of the individual forces is crucial for solving the problem.
abm77
A positive charge Q is fixed to the origin. A negative charge with magnitude 9Q is fixed along the positive x-axis a distance d to the right of the origin. Determine a point where a small positive test charge q will experience zero electrical force from the two charges, or show that there is no such point. Draw diagrams to help you.
[/B]
FE = kq1q2 / r2
(+Q)--------d---------(-9Q)
I know the test charge must be to the left of the positive charge Q, and I tried to solve by rearranging the equation to solve to r, but that leaves you with dividing the force, which in this case is zero which does not work.
r = √kq1q2 / FE
But FE = 0 so this does not work.
Your equation is for the force between two charges. There are three in the problem. The net force must sum to zero not the two individual forces.
So would the equation for three charges just include a q3 at the end? Thus making the small positive test charge 8Q to have it equal zero?
Not sure I follow that.
The test charge q is +ve so there are two forces on it..
1) A repulsive force between +Q an +q
2) An attractive force between -9Q and +q
The question asks where must +q be for these two forces sum to zero. Have you studied vector addition?
How would vector addition work for this question as there are no values for the variables?
The values are irrelevant, only the relative size of the charges is important (and you know that one has 9 times more charge than the other).
Place the test charge at an arbitrary position on the x-axis, then write an equation for F1 the force on the test charge from the one charge and another equation for F2 the force on the test charge from the other charge. The net force is F1+F2. The problem asks you to find where this net force is zero.
Likes CWatters
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
