A wire with a resistance R is lengthened to 1.25
  • Thread starter Thread starter discoverer02
    Resistance Wire
A wire with resistance R is stretched to 1.25 times its original length, prompting a calculation of its new resistance. The initial approach incorrectly assumed a direct proportionality between the decrease in radius and the increase in length. The correct relationship considers that volume remains constant, leading to a proportional decrease in cross-sectional area. This results in the new resistance being R2 = 1.56R1, aligning with the textbook answer. The discussion highlights the importance of understanding the relationship between length, area, and resistance in conductive materials.
discoverer02
My answer for this problem doesn't agree with the answer in the back of my textbook book:
A wire with a resistance R is lengthened to 1.25 times its original length by being pulled through a small hole. Find the resistance of the wire after it has been stretched.
R = pL/A
p = resistivity
L = length
A = area of a cross section perpendicular to the length
r = radius
R1 = pL1/A1
L2 = 1.25L1 so r1/r2 should equal 1.25 right.
The decrease in radius should be proportional to the increase in length.
So r2 = r1/1.25
Therefore R2 = p(1.25L1)/[pi](r1/1.25)^2 = R1(1.25*1.56) = 1.95R1
The answer in the back of my textbook is R2 = 1.56R1
Where have I gone wrong?
Thanks
Should it? How would you go about proving this?
I'm assuming it's proportional. If it's not then I'm lost
Volume is constant, and volume is L*A, not L*r
You're right. Stupid me!
The area would have to shrink proportionally: A2 = A1/1.25 so R2 = 1.25*1.25R1 = 1.56R1.
Thank you very much for the help. :smile:
