Linear Elastic Analysis w/ Abaqus CAE: Truss Structure Assumptions
Abaqus CAE assumes that a simple truss structure behaves linearly elastic, meaning that the material's stress is directly proportional to strain. It considers the truss members to be pin-connected, allowing for axial loading without moments. The analysis also assumes that material properties are homogeneous and isotropic, with no initial imperfections or residual stresses. Additionally, it presumes that the displacements are small enough for linear theory to apply. Understanding these assumptions is crucial for accurate modeling and results in structural analysis.
g0ggs123
In a linear elastic analysis using Abaqus CAE what assumptions does abaqus make of a simple truss structure.
Cheers
Gordon
Cheers
Gordon
What is the context of your question? What is the application?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
