Interferometer Experiment: Rules for Adding Half Wavelength
  • Thread starter Thread starter KFC
    Interferometer
In interferometer experiments, a half-wavelength phase shift occurs during reflection when the index of refraction after the surface is greater than before, such as light reflecting off glass from air. This phase shift does not happen when light is transmitted through a beam splitter. If the reflector is imperfect or the beam splitter is not 50/50, the reflected portion still experiences a half-wavelength shift, while the transmitted portion does not. The concept can be understood as a phase shift of π radians rather than a literal addition of half a wavelength. Understanding these rules is crucial for analyzing wave behavior in optical experiments.
KFC
I am reading a scientific essay about a experiment with interferometer. They use so called 50/50 beam splitter and perfect reflector. Well they have the input wave be the plane wave exp(ikx), what interesting is: whenever the wave reflected by the splitter or perfect reflector, it add half of the wavelength to the wave, but if the wave was transmitted through the splitter, no wavelength was added to it. It is so confusing. What's the rule behind this?
1) When will the half wavelength being added to the wave? Only happen in reflection?
2) If the reflector is not perfect and the splitter is not 50/50 (30/70 or 80/20), will it still be a half-wavelength added? or any other portion of wavelength being added?
Only in reflection, and only when the index of refraction (n) of the material "after" the surface is greater than the index of refraction "before" the surface. E.g. when the light is traveling in air and hits a glass surface, the reflected wave has the half-wavelength added, but when the light is traveling in glass and hits a surface with air on the other side, this does not happen.
The portion of the wave that is reflected has the half-wavelength added (provided the index of refraction on the two sides is as described above), the transmitted portion of the wave does not (regardless of how the index of refraction goes).
It's not exactly adding a half-wavelength, it's more correctly a reversal of the wavefront- equivalently, the phase is advanced 1/2 of a period when reflections occur from some interfaces, while the phase is not advanced when reflection soccur from other inteerfaces:
http://www.kettering.edu/~drussell/Demos/reflect/reflect.html
Yeah, some books handle it as a phase shift of \pi radians (which is what it "really" is), and some books handle it by adding \lambda / 2 to the optical path length, which is equivalent.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
