Is the Solution to the Absolute Value Inequality x^2<4 then |x|<=2 Correct?
The discussion centers on the validity of the statement "If x^2 < 4 then |x| <= 2." Participants clarify that solving the inequality yields -2 < x < 2, which implies |x| < 2, not |x| <= 2. There is a consensus that the original text likely contains a typo, as logically, if x^2 < 4, then |x| must indeed be less than 2. The confusion arises from the distinction between open and closed intervals. Ultimately, the conclusion is that the statement is true, but the notation used is misleading.
OceanSpring
Member warned about not using the homework template
Question:
True or False If x^2<4 then |x|<=2
My solution:
I get -2<x<2 when I solve the problem so it should be false. Yet the text says its true? Is this a mistake? If |x| is equal to 2 then it should be a closed interval, not an open interval which seems to be correct to me.
OceanSpring said:
Question:
My solution:
x2 < 4 is equivalent to -2 < x < 2 or |x| < 2. What the text has appears to be a typo.
OceanSpring said:
Question:
My solution:
It's probably a typo, although logically it is true:
If ##x^2 < 4## then ##|x| < 2## hence ##|x| \le 2##
If it were false, then there would be ##x## with ##|x| > 2## yet ##x^2 < 4##
Likes schlynn
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
