Absolute Value with Quadratic: What Are the Solutions to |x^2 + 6x + 16| < 8?
In summary, Homework Statement: Very embarrassed that I had problems with this. I managed to solved it at the end, but I am posting this for two reasons. First, I want to see what other approaches there are, and second, I want to see whether my solution is taking too long or not.
flyingpig
2,579
Very embarrassing that I had problems with this. I managed to solved it at the end, but I am posting this for two reasons
1) I like someone else to work it out in a different method, I wnt to see what other approaches there are
2) Whether mine is taking too long or not. I mean I solved it, but any unnecessary steps?
3) Check whether I am right or wrong lol
[tex]|x^2 + 6x + 16| < 8[/tex]
At first I was going to do
[tex] - 8 < x^2 + 6x + 16 < 8[/tex]
Then I realize it was hopeless
So then I did
[tex] (x^2 + 6x + 16) < 8[/tex] and [tex] - ( x^2 + 6x + 16 ) < 8[/tex](1) [tex] (x^2 + 6x + 16) < 8[/tex][tex] x^2 + 6x + 8 < 0[/tex][tex] (x+4)(x+2) < 0[/tex]
Did some test points and found that [tex] x \in (-4,-2) [/tex] is a solution
(2) [tex] -(x^2 + 6x + 16) < 8[/tex]
[tex] -(x+4)(x+2) < 0[/tex]
[tex](x+4)(x+2) > 0[/tex]
Now here is the problem should i have even divide that -1 and switch the inequality signs? I could and I would get some meaningless answer like [tex]x \in (-\infty,-4)[/tex]
Anyways I threw it back in
[tex](-x-4)(x+2) > 0[/tex]
x is still 4, so no change, neither did the solution
So my solution remains as [tex]x \in (-4,-2)[/tex]
The second line is wrong.
ehild
This isn't hopeless. Solve both cases separately, mainly:
[tex]-8<x^2+6x+16[/tex]
[tex]x^2+6x+16<8[/tex]
and then find the intersection of each solution set.
This is equivalent to
And you can improve on this part
flyingpig said:
(x+4)(x+2)<0Did some test points and found that
x∈(−4,−2)
By simply drawing a rough sketch of the quadratic (you should be able to visualize it in your head even).
And ehild has pointed out your error.
What you did is basically say that since a<b (from your first inequality) then a-b<0, but if -a<b, then -a-b<0 but -a-b is not equal to -(a-b) as you did.
One more point: Even though you solved the wrong quadratic,
x∈(−4,−2)
This would not be true since you need to find the intersection of the solution sets [itex]x\in(-\infty,-4)[/itex] and [itex]x\in(-4,-2)[/itex] which is the empty set (x cannot be in both at the same time, so there is no x satisfying these solution sets).
ehild
But I thought
|x| < a
is
-x<a and x <a
A definition of piecewise?
flyingpig said:
But I thought
|x| < a
is
-x<a and x <a
Look more closely, that's not what the problem was.
flyingpig said:
But I thought
|x| < a
is
-x<a and x <a
Or equivalently, x > -a and x < a. This is normally written as -a < x < a, assuming a is a positive number.
I don't understand your thinking here.
ehild
To take what ehild wrote, one or two steps farther;
If [itex]- ( x^2 + 6x + 16 ) < 8\,, [/itex] then [itex]-(x^2+6x+24)<0\,.[/itex]
Now solve that.
You might try completing the square for the quadratic, x2 + 6x + 16 .
x2 + 6x + 16 = x2 + 6x + 9 + 7
= (x + 3)2 + 7​
For on thing, this tells you that the minimum value for the quadratic is 7.
But there aer no real solutions for x^2 + 6x + 24
That means, it never crosses the x axis. It is either positive or negative everywhere. Which one?
ehild
Notice the post just before yours:
SammyS said:
= (x + 3)2 + 7
Yeah so you can't solve it, it's always positive and never less than 0.
If we're trying to solve [itex]-(x^2+6x+24)<0[/itex] this is equivalent to solving [itex]x^2+6x+24>0[/itex] :wink:
So −8<x2+6x+16 is always true.
ehild
Oh okay so that means all values of x will work, but doesn't this contradict my answer that (-4,-2)
No, the other side of the inequality holds only in the interval (-4,-2)
ehild
x has to be satisfied by both solution sets at the same time. It's called taking the intersection.
Well, [itex]x^2+6x+16[/itex] is positive for all x.
What does that tell you about [itex]\left|x^2+6x+16\right|\,?[/itex]
Not changing...
flyingpig said:
Not changing...
So if |x2+6x+16| means to take the positive value of "x2+6x+16" and "x2+6x+16" is always positive, then you do you really need the modulus sign?
No...
1. What is absolute value with quadratic?
Absolute value with quadratic refers to the process of finding the absolute value of a quadratic function, which is the distance between the vertex of the function and the x-axis. This can be calculated by taking the absolute value of the coefficient of the quadratic term and dividing it by 2 times the absolute value of the coefficient of the linear term.
2. Why is absolute value with quadratic important?
Absolute value with quadratic is important because it allows us to determine the minimum or maximum value of a quadratic function. This information is useful in various real-world applications, such as determining the optimal value in a business problem or finding the maximum height of a projectile.
3. How is absolute value with quadratic different from regular absolute value?
Absolute value with quadratic is different from regular absolute value in that it involves a quadratic function, which has an x^2 term, while regular absolute value involves a linear function, which has an x term. Additionally, absolute value with quadratic takes into account the coefficients of the quadratic function, while regular absolute value does not.
4. Can absolute value with quadratic have a negative value?
No, absolute value with quadratic cannot have a negative value. The absolute value of a number is always positive, and in the case of absolute value with quadratic, it represents a distance which cannot be negative.
5. How is absolute value with quadratic used in real-world situations?
Absolute value with quadratic is used in real-world situations to solve optimization problems, such as finding the minimum or maximum value of a quadratic function. It is also used in physics and engineering to determine the maximum height or distance of a projectile, as well as in business and economics to find the optimal value in various scenarios.
