Abstract - one to one and onto questions
  • Thread starter Thread starter kathrynag
    Abstract
kathrynag
Determine whether the given function is one to one and whether it is onto. If the function is both one to one and onto, find the inverse of the function.
f:R^{2}\rightarrowR^{2}, f(x,y)=(x+y, y) .
I know one to one says f(x)=f(y) implies x=y
Onto means if for every element y in R^{2}, there exists an element x in R^{2} with f(x)=y.
I conceptually understand the idea, but don't know how to use these definitions.
Let S={1,2,3} and T={4,5}
I need to find how many functions are there from S into T? T into S? And how many of there are one to one and onto.
My problem with this is getting a function from a set.
You may find it a bit less confusing if you use letters other than x and y. For the function you've been given, you're trying to show that if f(a)=f(b), then a=b, where a=(x1,y1) and b=(x2,y2). Similarly, to show it's surjective, you want to show if f(a)=b, you can solve for a. Just write down the two equations each vector equation represents in terms of the components of a and b and solve them.
Suppose s and t are elements of R2 such that f(s) = f(t)
And so s = t.
Therefore, f is one-to-one.
Presumably, you'd use the definition of f somewhere in there, and of R2.
From a set theoretic point of view, a function is just a list of ordered pairs (x,y) where x is an element of S and y is an element of T. So start by writing down a list of all possible ordered pairs you can have. These are the elements of the cartesian product SxT. A function from S into T will be a subset of that set, so the problem is figuring out how many subsets you can find of SxT.
So f(x)=x+y
and f(y)=y
Now to show f(a)=b
f(a)=a+y says f(a)-a=y
f(a)=y
So it is onto?
Oh ok so something like (1,4) is one function?
kathrynag said:
So f(x)=x+y
and f(y)=y
Now to show f(a)=b
f(a)=y
So it is onto?
No, f(x) and f(y) don't make sense because x and y are not elements of R2. What are the domain and codomain of f? What do elements of the domain and codomain look like?
I was too sloppy. It's not all subsets of SxT but only those which satisfy the definition of a function, namely that it's single-valued.
Suppose you have a domain S={1,2,3} and codomain T={a,b,c}. The cartesian product SxT is the set consisting of all ordered pairs: SxT={(x,y) | x is in S and y is in T}. In this case, you'd have
SxT={(1,a), (1,b), (1,c), (2,a), (2,b), (2,c), (3,a), (3,b), (3,c)}
A function f from S to T is a subset of SxT which satisfies the requirement that an element in S maps to one value in T. For example, if you had
f={(1,a), (2,b), (3,c)}
this would be the function where, in more common notation, f(1)=a, f(2)=b, and f(3)=c. On the other hand, the subset
g={(1,a), (1,b)}
is not a function because it would mean that g(1)=a and g(1)=b, which you know isn't true for a function.
domain is x+y, codomain is y
No. When you write f:A→B, that means A is the domain and B is the codomain. So in your problem, both are R2. So f maps one ordered pair (x,y) in the domain to the ordered pair (x+y,y) in the codomain.
Ok so then I need to show f(a)=b
f(x,y)=(x+y,y)
f(a)=(x+y,y)
g={(1,a), (1,b)}
I don't understand why the codomain is not {4,5}
g={(1,a), (1,b)}
Could I say we have a function defined by f(1)=4, f(2)=4, f(3)=4
Another function defined by f(1)=5, f(2)=5, f(3)=5
Another defined by f(1)=4, f(2)=4, f(3)=5
And so on... Is that the idea?
Oh, I was just giving you an example. The codomain is {4,5} in your problem.
Exactly.
f(x,y)=(x+y,y)
f(a)=(x+y,y)
Or could I say something like f(x0,y0)=(x,y) is what I want to show.
Then f(x0,y0)=(x0+y0,y0)
So not onto.
