Acceleration and velocity question
To determine how long it takes for a cart to reach a velocity of 90 km/h, the velocity must first be converted to cm/s. The average velocity calculated from the lab data is 166 cm/s, which represents the slope of the velocity vs. time graph. Using the equation v = (166 cm/s²)t, one can solve for time t when v equals the converted velocity of 90 km/h. For the second question, the velocity at t = 5 seconds can be found by substituting 5 into the same equation. Understanding these calculations will clarify the relationship between velocity, time, and acceleration.
bango
hey, i have a lab due for a grade 10 physics class tomorrow. I am not too smart with this stuff, and I'm stuck with this question. can someone please help me out;
Question: how long would it take a cart on a similar ramp to reach a velocity of 90km/h?
i did a lab where we measured the speeds of a cart going down a ramp with a ticker tape timer thing.
i calculated that the average velocity was 166cm/s [down]
... there's one more question too;
calculate the velocity the cart would have if it was allowed to run down a similar ramp for a period of 5.0s
im sure this is real basic stuff, I am just stuck
my data was
time 0.0 velocity (cm/s) 0
time 0.05 velocity 16
time 0.15 velocity 31
time 0.25 velocity 47
time 0.35 velocity 63
time 0.45 velocity 72
time 0.55 velocity 99
time o.65 velocity 107
time 0.75 velocity 123
time 0.85 velocity 183
time 0.95 velocity 154
its basically uniform when plotted on a velocity vs time graph
Your graph has all the information you need. Draw the best straight line you can through your data and extrapolate (extend) your graph to longer times and higher velocities if needed. For the first question, you need to convert from km/hr to cm/sec. At what time does the graph cross 90km/hr? (Average velocity is not the most direct approach to answer this question. The number you have for average velocity is not what the data says. Are you sure that is velocity?)
For the seond question, what velocity is on your graph at t = 5 sec?
Extrapolation of the graph can be done in your mind if not done on paper. What is the slope of the graph? How can you use that to decide where points would be at larger times and larger velocities?
Try and get an equation for the graph and everything should be easy from there.
im still stuck, i understand what you're saying. but i don't know how to do it. i don't know proper equations, that's why I am on these forums
Your data graph is "uniform" you said. I take that to mean a straight line. The general equation of a line is
y = mx + b
In your case y is velocity, and x is time. b is the value of y when x is zero, which is zero for you. The equation that represents your line is
v = mt
and you calculated the slope to be 166m/s^2, except that you did not get the units right. We call the change in velocity divided by the change in time acceleration, and that is the slope of your graph. Your equation is
v = (166cm/s^2)t
Using that equation, you can figure out what time gives a velocity of 90km/hr, but you need that velocity expressed in cm/sec. The best way to convert units is to multiply what you have by fractions that are equal to one that replace unwanted units with wanted units.
90\frac{km}{hr}=90\frac{km}{hr}\left[\frac{1000m}{km}\right]\left[\frac{100cm}{m}\right]\left[\frac{1hr}{60min}\right]\left[\frac{1min}{60sec}\right]= how-many\left[\frac{cm}{sec}\right]
Plug the result into the equation relating v and t and solve for t.
For the last question, plug in for t to find v.
