How Do I Solve These Gravity-Related Physics Problems?
The discussion revolves around solving two gravity-related physics problems involving motion on the Moon and Neptune. The first problem requires calculating the distance an object falls on the Moon with an initial velocity of 636.8 cm/s over 1.1 seconds, while the second involves an object on Neptune falling from a height of 56.8 m with an initial downward velocity of 152.4 cm/s over 22.5 seconds. The user expresses frustration in finding the correct approach and has attempted various formulas without success. There is a suggestion to clarify the methods used for solving the problems to better visualize the concepts involved. Overall, the user seeks guidance to navigate these two-dimensional motion problems effectively.
jbgibson
I'm having difficulty with these two problems:
1. A mass is moving towards a massive crater (along the +x direction) on the Moon with an initial velocity of 636.8 cm/s. How far will the object fall in the first 1.1 seconds.
2. An object initially displaced 56.8 m (along the horizontal x direction) has in initial velocity downward (along the -y direction) of 152.4 cm/s. If this object is on Neptune, how far (in meters) will it fall after 22.5 seconds?
I'm not looking for the answers, I just need someone to point me in the right direction. I have attempted solving several different ways to no avail. The acceleration due to gravity on the Moon is 1.6 m/s2 and 14.07 m/s2 on Neptune. Thanks in advance!
JB Gibson
Could you solve the problem if this was the Earth and not the moon or Neptune?
If not, it would help if you were to show us the several different ways you attempted.
I'm not able to visualize the concept right now. I realize the problems are dealing with 2-dimensional application, but I'm puzzled. I tried applied the formulas:
y=yo+vot+1/2gt^2
y=1/2gt^2
y=(vo sin)t-1/2gt^2
Let's see...my initial velocity in the y-position is 0 and I don't have any initial position. Like I mentioned, I just need someone to point me in the right direction. It's been a while since I had a Physics class. TIA!
JB Gibson
If a=-g=-1.6m/s^2 on the moon, is the solution to problem #1:
y=-1/2gt^2=-96.8cm?
I submitted this as my answer, but it is incorrect. I don't know anymore; maybe I should just give up.
Any help is greatly appreciated.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
