Mastering Acceleration: Easily Solve for Time with this Simple Formula
  • Thread starter Thread starter licorice
    Acceleration
To determine how long it takes for a book dropped from a height of 1.5 meters to hit the ground, it's essential to use the correct kinematic equations that include time as a variable. The equation V^2 = V_o^2 + 2aΔx does not incorporate time, making it unsuitable for this problem. Instead, the relevant kinematic equation is S = ut + 1/2at^2, where 'S' is the distance fallen, 'u' is the initial velocity (zero in this case), 'a' is the acceleration due to gravity, and 't' is the time. The acceleration is typically taken as -9.8 m/s^2 when falling towards the ground. Understanding these equations and their variables is crucial for solving kinematics problems effectively.
licorice
Acceleration Help?
a book is dropped from a had to the ground 1.5m, how long will it take to hit the ground?
(v2)2 = (v1)2 =2ax?
I am not sure if the equation is the correct one to use, and i am having trouble with the algebra part.
a book is dropped from the ground?
Sorry... from his hand to the ground.
Look for a kinematic equation for position not velocity.
So the equation you listed,
V^2 = V_o^2 +2a \Delta x
Has 4 variables, none of which are time. I suggest you look at the kinematic equations and select the one with all of the variables you have and need to solve for.
So the variables you already know (or can deduce) are what? (ie have numerical values for)
The variable you need to solve for is what?
what is a kinematic equation?
My apologizes, llello is right.
kinematic equation = equation of motion (this usage should be in your book)
I have distance, gravity, v1 and v2 and i am looking for time. Is it (v2)2 = (v1)2=2gy?
So a general way to go about kinematics problems:
- Note that in all of the equations only 5 variables appear: t, \Delta x, v, v_o, a
- These represent time, displacement, final velocity, initial velocity and acceleration.
- Each individual equation only contains 4 variables.
- Generally you are given 3 variables and want to solve for a 4th.
- Pick the equation that has the 3 known variables and the 4th unknown.
- Solve for the unknown.
- You may have to infer some things about the situation described. For example, it may tell you that you are on earth, so a = -9.8 m/s^2 (if you choose up to be the +y direction). Similarly, you may be told that an object reaches a maximum height before falling back down; at max height v = 0.
You can use this formula S=ut+1/2at^2 and take a=9.8m/s^2. Since it is falling to ground the acceleration is positive.
Really? You have V2? What is it?
