Acceleration of the helicopter as it starts to rise
The problem involves calculating the acceleration of a helicopter with a mass of 2500 kg, which propels 2400 kg of air downward at a speed of 11 m/s. The net force is calculated as 26400 N, factoring in the weight of the helicopter. The correct acceleration is derived from the equation 26400 - 2500(9.81) = (2500)a, leading to an acceleration of 0.75 m/s². However, there is confusion as the expected answer is 9.58 m/s², suggesting a possible error in the mass used in the calculations. Clarification on the textbook source indicates a potential misprint in the problem statement.
anlenemilk
At take off, the rotor blades of a helicopter propel 2400 kg of air vertically downwards each second. The air, intially at rest, is given a speed of 11ms^-1
QN: the mass of the helicopter is 2500 kg. Find the acceleration of the helicopter as it starts to rise
<F>=Change in momentum /change in time
Fnet=ma
= (2400*11-0)/1= 26400N
26400-2500(9.81)=(2500)a
a=0.75ms^-2
The answer is 9.58ms^-2
I have no idea how to get this answer! HELP ME! THANK YOU VERY MUCH
I'd say that your answer is correct and the given answer is wrong.
What textbook is this problem from?
Note that you'll get the given answer if you changed one of the masses to 250 (which is clearly wrong):
26400-250(9.81)=(2500)a​
That could be how the wrong answer was attained.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
