How Do You Calculate Maximum Speed from a Non-Constant Acceleration Time Graph?
To calculate the maximum speed of a particle from a non-constant acceleration time graph, the area under the acceleration curve represents the change in velocity. The particle starts from rest, and the maximum speed is determined at t=11 seconds, yielding a value of 55 m/s based on the area calculation. The discussion highlights the importance of correctly integrating the acceleration function over time, emphasizing that acceleration can vary and is not constant. Misunderstandings about the definitions of rest and acceleration are clarified, noting that a particle can start at rest while still experiencing acceleration. Ultimately, proper integration techniques are essential for accurately determining velocity from the acceleration graph.
Suraj M
A particle starts from rest. Its acceleration vs time graph is as shown. What will be the maximum speed?
usual kinematic equations(3+)
velocity at t=11 seconds should be max, so the area under the given graph = change in velocity
So vf-0 = 55
so max. velocity= 55 m/s
But, if i try it this way:
##a=\frac{dv}{dt}##
##a.dt=dv##
integrating..
##a∫_{0}^{11} dt = ∫_{0}^{v} dv##
so ##a(11-0)=v-0##
i know this is wrong because ##a## is not constant. But how do i include it?
Any help is appreciated.
Suraj M said:
a.dt=dva.dt=dv
integrating..
a∫₀11dt=∫₀vdva∫₀^{11} dt = ∫₀^{v} dv
Since a is a function of time, ∫adt is not a∫dt
You need to write a as a function of t then integrate it correctly.
But if a particle starts from rest and its acceleration vs time graph is as shown, I ask to myself why at the intial time the initial acceleration is not null?
I ask to myself why at the initial time the initial acceleration is not null?
You could equally ask, why the question chose to set time 0 at the moment the acceleration starts.
Seems a sensible choice. Say the acceleration is given by a spring which is compressed. It could sit in that state indefinitely, until you release the particle. Then something interesting happens, so you start measuring from that moment and call that t=0.
To keep you happy, acceleration was 0 or null at t=-1, t=-7.5, t= -0.000000000000000000001, but rises to 10 m/sec2 (or whatever that blurred figure is) at t=0.
Likes Pierce610 and Suraj M
oh yeah, i don't how i missed that..
so ##a=10-βt## where ##β= \frac{da}{dt}##
so ##β=\frac{10}{11}##
so i get $$∫_{0}^{11}(10 - \frac{10}{11}t)dt =∫_{0}^{v}dv$$
so then i get ## 10(11-0)-(\frac{10}{11}).(11^2 -0) = v##
so ##v = 110-110=0## huh?
Suraj M said:
so i get ##∫_{0}^{11}(10 - \frac{10}{11}t)dt ##
Try this integration again. Show intermediate steps.
$$∫_{0}^{11}(10dt -\frac{10}{11}tdt)=∫_{0}^{v_f}dv$$
$$10(t_f -0) - \frac{10}{11}(\frac{t_f^2}{2}-0)=v_f-0$$
so then substituting ##t_f=11##
Ok got it.. thanks, sorry for the stupid mistake
What is the integral of tdt? (Hint: it's not t2)
Chet
Likes Suraj M
What physical law that you are aware of says that the acceleration of a particle has to be continuous with time?
Chet
Yes. It's just your integral.
∫ k dt = kt , but ∫ kt dt ≠ kt2
Try differentiating kt2 and see what you get.
Edit - You posted the right answer while I was writing this!
Thank you, i corrected it.. in post #7
thank you for your help.
Mr. Chet ,
I wanted only say that the particle in question is defined to "start at rest" while in the graph, for how I think to interpretate it,seems to start with an initial acceleration not null. Isn't definition of rest "no acceleration"?
Pierce610 said:
Mr. Chet ,
No. Definition of "at rest" is zero velocity.
Chet
Chet
and then also the acceleration?
No. Acceleration is rate of change of velocity.
but then let me know how is the acceleration of a particle at rest, that is with speed null?
Imagine that, at times t<0, the velocity is zero, and at times t>0, the velocity is kt, where k is a constant. So the velocity is a continuous function of time. What is the acceleration at times t < 0? What is the acceleration at times t > 0? Is the acceleration a continuous function of time at t = 0?
Chet
Likes Pierce610
I've understand: before a particle moves with constant speed v, it needs to be accelerated.
It can't move from 0 to v instantly. Also in free fall it should be an acceleration not null at the start time, 9.8 m/s^2
If a stationary particle were to have no acceleration, it would forever remain at rest.
