Activated carbon vs. Typical bonfire coal
  • Thread starter Thread starter civil_dude
    Carbon Coal
Activated charcoal and activated carbon differ primarily in their surface area and reactivity. Activated charcoal has a significantly higher surface area, which can reach up to 2 square kilometers per gram, making it highly effective for filtration and pyrotechnics. This increased surface area allows for more reactive sites, enhancing its ability to absorb chemicals and impurities compared to regular coal-carbon, which contains many impurities and is denser. While activated carbon is chemically treated to maximize its surface area and reactivity, once it has been fully utilized, its effectiveness may diminish, approaching that of coal-carbon.
civil_dude
Does anyone know the difference? Specs and such?
Thanks
Chemistry news on Phys.org
Activated charcoal has lots more surface area to help for filters and stuff... They can make it with 2 square kilometers in a gram I hear.
Activated Carbon is specially treated/made to that the particles have a very high surface area.
This increased surface area of Activated Carbon over regular coal-Carbon makes it much more reactive (more surfact area means more spots for a reaction to take place) and very desireable for use in pyrotechnics and in carbon filtration.
Normal choal-carbon contains many inpurities compared to the chemically altered activated carbon, but I assume that you meant coal-carbon without it?
Activated Carbon has a high surface area that allows it to absorb water and other such chemicals from the air. Coal is way too dense for this. However, if the activated carbon has been used to its full extent, it will be about the same thing as the coal.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
