Find Ice Mass to Make Water Temp 29°C
  • Thread starter Thread starter Magicarp
    Ice Water
An insulated beaker contains 0.275 kg of water at 77.7°C, and the goal is to determine how much ice at -17.4°C must be added to achieve a final temperature of 29°C. The calculations involve using the specific heats of water and ice, as well as the heat of fusion. The initial attempt yielded 0.114 kg of ice, but discrepancies arose due to significant figure considerations and rounding errors. Another participant calculated 0.11277 kg, confirming that extending significant figures could resolve the issue. The discussion emphasizes the importance of precision in calculations for online assessments.
Magicarp
An insulated beaker with negligible mass contains liquid water with a mass of 0.275kg and a temperature of 77.7.
How much ice at a temperature of -17.4 must be dropped into the water so that the final temperature of the system will be 29.0?
Take the specific heat of liquid water to be 4190 , the specific heat of ice to be 2100 , and the heat of fusion for water to be 334 x 10^3 .
Q = mc\DeltaT
Q_tot = q_1 + q_2 ..etc
Fusion - Phase change
I am almost certain I have done this correctly, but masteringphysics will not admit it! :/
I will leave off some units as I have made sure they all match up.
q1: Ice to 0C
q2: Ice fusion mw= mass water
q3: Ice to 29C mi = mass ice
q4: H20 to 29C((mw)(4190)(29C-77.7C) + (mi)(2100)(0C+17.4C)+(mi)(334 X 10^3)+(mi)(4190)(29C-0C))= 0
I solve for mi and get 0.114kg ice. MP no likey. Anyone care to check this?
Thanks in advance,
Magicarp
Welcome to PF.
If it's any consolation I get a different answer from you.
Perhaps you should recalculate a little more carefully?
I initially dropped a term but it was inconsequential, and still different from your answer.
Edit: but quite close to yours. Maybe carry more precision?
Thanks for the speedy response! Are you sure there is nothing to fix in the setup? I could extend the answer to more sig figs, but this is one of those questions where MP conveniently doesn't tell you how many sig figs to include. It tells me that my answer is close and I may have rounded or used the incorrect number of sig figs. But usually when it says this, the answer is different by quite a lot.
I'd say your method is apparently OK.
I got .11277 kg when I equated what heats up to what cools down. In quickly checking your terms it seems your signs are OK.
Thanks LowlyPion, I simply had to extend the sig figs by 1 digit.
Cheers,
Magicarp
I would have to back you up.
You are given the data to 3sig figs, more than 3sig figures in the answer is wrong. That's why I hate these online test things
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
