Calculating Impedances in Polar Coordinates: Tips and Tricks
To add three impedances in polar form, it's recommended to convert them to rectangular coordinates for easier calculations, especially when dealing with series and parallel combinations. Multiplication in polar coordinates involves multiplying the magnitudes and adding the angles, while addition requires converting to rectangular form first. Modern calculators often have functions for converting between polar and rectangular forms, which can simplify the process. It's beneficial to practice several examples to become proficient in these calculations. Understanding these methods will help identify errors that may arise during calculations.
barry-
Hello all i have a question about adding 3 impedances given in polar form, must i convert them to x..y.. first or is there a quicker way on a calculator and if so can anyone give advice i have the equation Zo=√Z(oc)Z(sc) but finding it hard to understand many thanks.
Are you sure you didn't mean multiplying two impedances? In that case, if Zoc and Zsc are two complex impedances in polar form, their product is a new complex number with magnitude |Zoc|× |Zsc| and phase angel φoc + φsc.
barry- said:
[...]finding it hard to understand many thanks.
It's easier to understand many thanks if you use punctuation.
well its 3 impedance in series and parallel so if i use the formula z =z1z2/z1 + z2 and am i right that in polar form you multiply the x-axis and add the y (i.e the value given as the angle)? that will sort the 2 impedances out in parallel then the remaining impedance will be in series with that and i can just add them, Thank you
Congratulations on improved punctuation !
Yes - you can add in rectangular,
and you can multiply in polar as you described. I'd have said " Multiply the magnitudes and add the angles" , though. To say X and Y implies rectangular.
I learned this in slide rule days so it's ingrained.
I really suggest you work about ten examples on paper so it'll become habit for you.
I was through college before pocket calculators appeared. When the HP35 came out ~1972 with its one button polar-rectangular conversion the EE world was flabbergasted.
So there's probably an easy way to do it with a modern calculator. But you should become fluent in the method so you can spot errors coming from missed keystrokes.
My two cents !
old jim
:) thanks english is not a strong point of mine, thank you for the help, I am sure my calculater can add them but I am not sure how, so as long as it can convert between polar and rectangular and then do what i need to do il be happy, thank you.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
