Adding square roots of ##i## leading to different answers!
  • Thread starter Thread starter brotherbobby
    Complex numbers
The discussion focuses on evaluating the expression √i + √-i, with participants exploring different methods, including Euler's formula and geometric interpretations. Initial calculations suggest that the result is √2, but confusion arises when applying the method of surds, leading to questions about the principal values of square roots in complex numbers. Participants emphasize the importance of understanding the argument of complex numbers and the implications of choosing different branches for square roots. Ultimately, the conversation highlights the complexity of working with square roots in the complex plane and the necessity of adhering to consistent definitions to avoid discrepancies in results.
brotherbobby
##\textbf{Evaluate : }\,\boldsymbol{\sqrt{i} + \sqrt{-i}=?}##
1. ##e^{i\theta} = \cos\theta+i\sin\theta##
2. ##\cos\theta=\frac{e^{i\theta}+e^{-i\theta}}{2}##
Statement of the problem : We have to find what is ##\sqrt{i} + \sqrt{-i}##
First Attempt (Euler's Formula) : I use the Euler's formula (see Relevant Equations 1) above which yields ##i = e^{i\frac{\pi}{2}}##. Likewise ##-i = e^{i\left(-\frac{\pi}{2}\right)}##.
Now I evaluate
where, in the last step, I used Relevant
Equation no. 2 above 👆 which follows directly from Euler's Formula.
Second Attempt (geometry) : I use the fact from attempt 1 above wherein I showed that ##i = e^{i\frac{\pi}{2}}## and ##-i = e^{i\left(-\frac{\pi}{2}\right)}## to plot the two numbers into the complex plane as shown to the right. From the image it is evident that the imaginary parts of the two numbers vanish when put together. Their real parts however "add up" to yield
So far, I have been able to establish by slightly different methods that the answer to the problem ##\textbf{Evaluate : }\,\boldsymbol{\sqrt{i} + \sqrt{-i}}## is ##\boldsymbol{\sqrt{2}}##. So the answer is a real number.
But when I use the method of surds for the same problem, I run into trouble!
Third Attempt (Algebra, the method of surds) :
Doubt : Where am I mistaken? I suppose in taking the square room of the expression in the last but one step. But we are aware that in algebra when we have ##\sqrt{f(x)}##, the conditions are that (1) ##f(x)\ge 0## and (2) ##\sqrt{f(x)}\ge 0##. Acccordingly, I took the positive square roots in both cases. Of course for the second term ##(i-1)^2 = (1-i)^2##, and hence the positive square root in those cases are ##i-1## and ##1-i##. Why take one and not the other? Is this something to do with principal values?
A hint or comment would be most welcome.
My math is not formatted. I am not sure what the problem is.
Why did you assume that <br /> \sqrt{(i- 1)^2} = i - 1 rather than the correct (in the principal branch) <br /> \sqrt{(i-1)^2} = \sqrt{-2i} = \sqrt{2} e^{-i\pi/4} = 1 - i?
Likes topsquark, pbuk and malawi_glenn
I do not understand. Let's leave complex numbers aside for the time being.
If I were to give you ##\sqrt{(x-y)^2}##, would you say the answer is ##(x-y)## or ##(y-x)##? That is my confusion for the moment.
Do you think these conditions apply when ## f(x) ## has an imaginary part? Do you think that ## w \ge 0 ## has any meaning when ## w ## has an imaginary part?
Likes topsquark and malawi_glenn
If we limit x and y to ## \mathbb R ## and have ## x \ge y ## then the answer is trivial.
No, your confusion is that you are applying "rules" you learned when studying ## \mathbb R ## to ## \mathbb C ##.
Likes PeroK, topsquark and malawi_glenn
You simply have to re-learn what the square root symbol means in the context of non-real numbers
Yes good point. Let me clarify the case for real numbers first.
The expression ##\sqrt{(x-y)^2}## is ##\vert(x-y)\vert##. Thus it is ##(x-y)## if ##x>y## and ##(y-x)## if ##y>x##.
Now for complex numbers I am still confused. If I have ##\sqrt{(x+iy)}##, how do we go about it? It would be better to write ##x+iy = re^{i\phi}##. In that case, we have ##\sqrt{re^{i\phi}}=\sqrt{r}\sqrt{e^{i\phi}}##.
How do we decide ##\sqrt{e^{i\phi}}##?
Thank you for your patience.
What does your text book/lecture notes say?
Yes that's a good start, but note that you can do that in an infinite number of ways: ## e^{i\varphi} = e^{i(\varphi + 2n\pi)} ## so you need to choose ## \varphi ## in the same way as everyone else to get the same answer. What does your text book/lecture notes say?
Likes malawi_glenn and topsquark
Most often if ##w,z \in \mathbb{C}## then ##\sqrt{w} = z## means that ##z\cdot z = w## and ## - \pi /2\leq\text{arg}(z) \leq \pi / 2 ## but you should, as mentioned, check your textbook for this one. Different authors uses different "branches".
For instance
##\sqrt{-\text{i}} = \dfrac{1}{\sqrt{2}} - \dfrac{\text{i}}{\sqrt{2}}## because ##\left( \dfrac{1}{\sqrt{2}} - \dfrac{\text{i}}{\sqrt{2}} \right) \cdot \left( \dfrac{1}{\sqrt{2}} - \dfrac{\text{i}}{\sqrt{2}} \right) = -\text{i}##
but hey! ##\left( -\dfrac{1}{\sqrt{2}} +\dfrac{\text{i}}{\sqrt{2}} \right) \cdot \left( -\dfrac{1}{\sqrt{2}} + \dfrac{\text{i}}{\sqrt{2}} \right) = -\text{i}## too!!! But ##\text{arg}\left( -\dfrac{1}{\sqrt{2}} +\dfrac{\text{i}}{\sqrt{2}} \right) = 3\pi/4## so...
Now you check what ##\sqrt{\text{i}}## is, and your question will be resolved.
More generally, an interesting question is what is ##\sqrt z + \sqrt {z^*}##?
Likes malawi_glenn
pbuk said:
What does your text book/lecture notes say?Yes that's a good start, but note that you can do that in an infinite number of ways: ## e^{i\varphi} = e^{i(\varphi + 2n\pi)} ## so you need to choose ## \varphi ## in the same way as everyone else to get the same answer. What does your text book/lecture notes say?
Sorry to come in late. Thank you for the clarification.
Actually I picked the question online and don't have a textbook for it yet. Is it ok to say that a complex number is such that, given ##z=re^{i\phi}##, the value of ##\phi## should lie between ##[0,\pi]##. Or is it ##[0,2\pi]##?
The principle branch assumes that \arg z \in [-\pi, \pi). It follows that \arg(\sqrt{z}) \in [-\pi/2, \pi/2).
malawi_glenn said:
But arg(−12+i2)=3π/4 so...
Can you complete your answer? Are you therefore saying that ##\sqrt{-i}\ne \left( -\dfrac{1}{\sqrt{2}} +\dfrac{\text{i}}{\sqrt{2}} \right)##?
What do you get when you square the expression on the right side?
I left some work for you to think about. Read my post very carefully
Let me proceed. Indeed your question is more general than mine (post#1) where ##z=i\Rightarrow z^*=-i##.
Let ##z = re^{i\phi}##
\begin{equation*}
\begin{split}
\text{Let}\;\mathscr{E}&=\sqrt{z}+\sqrt{z^*}\\
& = \sqrt{r}(\sqrt{e^{i\phi}}+\sqrt{e^{-i\phi}})\\
&=\sqrt{r}(e^{i\phi/2}+e^{-i\phi/2})\\
& = \sqrt{r}\times 2\cos\phi/2\quad\text{Using Euler's formula}\\
& = \boxed{2\sqrt{r} \cos(\phi/2)}
\end{split}
\end{equation*}
In my problem, since ##z = i\Rightarrow |z|=|z^*| = 1=r## and since ##i = e^{i\phi/2}\Rightarrow \phi = \pi/2##.
Hence the expression ##\mathscr{E} = \sqrt{i}+\sqrt{-i} = 2\cos\pi/4 = \boxed{\sqrt{2}}## .
Is this correct?
Let me do it by writing. I hope it is legible.
So indeed we find ##-i##. However, the claim is that ##\sqrt{-i}\ne (-1/\sqrt 2+i/\sqrt 2)## but rather ##\sqrt{-i}\ne (1/\sqrt 2-i/\sqrt 2)##.
I think my problem is getting resolved because of the argument involved. This was @malawi_glenn 's point in post# 9 above.
To recapitulate, ##\sqrt{-i} = e^{-i\pi/4}##. The argument of the complex number ##\sqrt{-i} = -\pi/4##. We can write that ##\sqrt{-i} = 1/\sqrt{2}-i/\sqrt{2}## not only because the latter "squares" to give ##-i## but also because its argument is the same as that of ##\sqrt{-i}##, viz. ##-\pi/4##.
On the other hand, ##\sqrt{-i} \boldsymbol{\ne} -1/\sqrt{2}+i/\sqrt{2}## even though the latter squares to give ##-i##. This is because its argument is ##3\pi/4\ne -\pi/4##, as will be evident from its position on the complex plane.
I hope my reasoning is correct.
Yes it is correct. Though as some of us mentioned, there are other choices for the "branch" so you have to control it against your textbook's definition
I don't follow what other choices can there be. Let's see.
We have a (complex) number like ##\sqrt{i} = e^{i\pi/4}##. The modulus of this complex number is 1 and its argument is ##\pi/4##. Where is the choice for the argument?
Or did you mean something else?
Just look at the square root of a positive real number ##x##. We define ##\sqrt{x}## to be the positive real number such that ##\sqrt{x} \cdot \sqrt{x} = x ##. Another definition would be to say that ##\sqrt{x}## is the negative real number such that ##\sqrt{x} \cdot \sqrt{x} = x ##. Thus, in our definition of what the square root of a positive real number should equal, we made a choice of "branch".
Similarly for the square root of a non-real number, we choose a "branch" - in the definition I gave we said that the square root of a non-real number should have an argument between ##- \pi/2## and ##\pi/2##.
As you saw in the example I gave you, if we just said that ##\sqrt{-\text{i}}## should be a number which when squared, equals ##-\text{i}##. There are two numbers which satifies that, nameley ##1/\sqrt{2} - \text{i}/\sqrt{2}## and ##-1/\sqrt{2} + \text{i}/\sqrt{2}##. Now, which one of these should we pick? That is why we need "another ingredient" to our definition of the square root of a non-real number,
Adding 2\pi to the argument of a complex number does not change its real or imaginary parts, but does add 2\pi i to its logarithm.
This is why we need to choose an interval of width 2\pi in which we regard the argument as lying. The standard branch uses [-\pi, \pi). The reason for this is that the jump discontinuity in \arg z is then along the negative real axis, which is convenient for applications such as inverting Laplace transforms or obtaining integral representations of various special functions.
Likes malawi_glenn
