Adiabatic Process: No Energy Change but Temperature Change?
An adiabatic process is characterized by no heat energy transfer into or out of the system, resulting in no net energy change. However, changes in pressure, volume, and temperature occur due to the internal energy changes of the gas, which are equal to the work done on or by the gas. This distinction is crucial, as highlighted by Prof. Zemansky, who emphasizes that heat should not be considered separate from internal energy in thermodynamic discussions.
  • Understanding of thermodynamic principles
  • Familiarity with the concept of internal energy
  • Knowledge of pressure-volume work
  • Basic grasp of molecular vibration and temperature correlation
  • Study the First Law of Thermodynamics in detail
  • Explore the concept of internal energy in ideal gases
  • Learn about pressure-volume work calculations in adiabatic processes
  • Investigate the teachings of Prof. Zemansky on thermodynamics
Students of thermodynamics, physics educators, and professionals in engineering fields who require a deeper understanding of adiabatic processes and energy transformations.
EIRE2003
In an Adiabatic Process no heat energy is trasferred into or out of the system so there is no energy change, BUT, there is a change in pressure, volume and temperature.
But when atoms or molecules gain/loose heat energy they vibrate more/less respectively. And the measure of the vibration of the atoms/molecules is the temperature, am I right? So my question is Why is there no energy change but a temperature change?
Thanks
Science news on Phys.org
Thanks
There is an energy change. It is a change to the internal energy of the gas. The energy change is equal to the amount of work done by or to the gas.
This is an area that causes confusion. Prof. Zemansky would say that you should not talk about heat as distinct from internal energy. This is probably a good idea, but that is not yet the way thermodynamics is taught.
AM
  • · Replies 22 ·
  • · Replies 60 ·
10K
