Aerodynamic efficiency and static longitudinal stability
granbycools
Hello,
I am looking for research results, report etc. dealing with
-aerodynamic efficiency and static longitudinal stability-
Couldn´t find anything useful yet!
Any ideas would be very much appreciated.
Best Regards,
granby
What exactly do you mean? Do you want reports dealing with either aerodynamic efficiency OR static longitudinal stability? Or a report with aerodynamic efficiency as it relates to static longitudinal stability?
usually called "Trim Drag"...
the sweet spot is for the CG to be at the neutral point so that tail is making no lift.. but providing pitch stability through an active system (SAS)
a sailplane is a good example... the CG is just enough fwd of the neutral point that a pilot can control the plane... high pitch damping helps...
