Exploring Affine Hulls: 2D & 3D
  • Thread starter JasonJo
  • Tags
    2d 3d
In summary: Regrouping terms, we see that the affine hull of S is the set of all points expressible as affine combinations of points in S.In summary, the affine hull of two points in 2D is a line connecting the two points, the affine hull of three points in 2D is an infinite parallelogram or plane through the three points, and for n>3 points in 2D, it is a hyperplane that passes through all n points. In 3D, the affine hull of two points is the line that passes through both points, the affine hull of three points is a plane, and for n>4 points, it is the entire space. This concept is important in computational geometry and can
JasonJo
429
An affine combination of k points (x1, x2, ..., xk) is the sum of the form:
b1*x1 + b2*x2 + ... + bk*xk
with b1 + b2 + ... + bk = 1
where the condition that any of the b's do not have to be greater than or equal to zero, as it is required in the convex combination.
In 2D, what is the affine hull of two points? Three points? n>3 points?
In 3D, what is the affine hull of two points? Three points? n>3 points?
The professor said it was easy but I'm still not quite yet grasping the concept.
thanks guys
Well, I can imagine two ways to proceed:
(1) Draw a picture.
(2) Work through algebra.
thanks guys
With a convex combination, such at you bi must be between 0 and 1, you get the area between the points.
What is the convex hull of two points? The convex hull of 3 points?
Now extend that outside the points, allowing the bi to be negative or greater than 1. Your professor was right- it is easy.
eh wow, i really feel like a dummy.
in 2D i got:
2 points - the affine hull is the line connecting the two points
3 points - the affine hull is an infinite parallelogram or plane through the 3 ponts
n>3 - I'm *guessing* it's the hyperplane that passes through all n points?
in 3D i got:
2 points - the line that passes through both points
3 points - no idea (i would guess the plane)
4 points - no idea ( i would guess a sphere)
n>4 points - no idea (no clue at all)
There are hyperplanes in 2-D??
yeah hyperplanes in 2D are called lines =] j/k but really ithink they are(isn't the def'n of a hyperplane as something that divides the region in 2 halvesn>3 points in 2D with the given non-convex criteria is the plane isn't it...that is if they are not all colinear
3 points in 3D is easy...think vectors draw them out and then think what you can get from those vectorpick up o'rourke computational geometry book in there I'm sure he has the proofs in there.
You're right -- but I figured quibbling over the details would disrupt the spirit of my interjection!
that'sthe book I'm using right now, it's good but it's really advanced for me.
In 2D the affine hull of 3 or more points is the entire plane.
In 3D the affine hull of 4 or more points is the entire space.
I feel I should point out, since it hasn't been mentioned yet, that this is for three generic points -- there are special cases where this would fail.
also assuming nonconvex right? or rather the restriction stated in the first post?
Oh I just noticed you did mention this exception.
Yah, I said the affine hull (as opposed to the convex hull).
Jason: if you want some intuition, the point of these things is:
The convex hull of S is the smallest convex set containing S.
The affine hull of S is the smallest affine set containing S.
1. What is an affine hull in 2D and 3D?
The affine hull in 2D and 3D refers to the set of all points that can be created by taking linear combinations of a given set of points. It is a subset of the vector space that contains the original points and is closed under addition and scalar multiplication.
2. How is an affine hull different from a convex hull?
While an affine hull contains all possible linear combinations of points, a convex hull only contains the points that lie on the boundary of a convex shape formed by those points. The convex hull is a subset of the affine hull.
3. What is the importance of exploring affine hulls in 2D and 3D?
Exploring affine hulls allows us to understand the relationship between different points and how they can be combined to form new points. This has applications in computer graphics, optimization, and data analysis.
4. How is the affine hull calculated in 2D and 3D?
The affine hull can be calculated by finding the basis vectors of the given points and then taking all possible linear combinations of those vectors. In 2D, the affine hull is a line, and in 3D, it is a plane.
5. Can affine hulls be explored in higher dimensions?
Yes, affine hulls can be explored in any number of dimensions. The same principles of finding basis vectors and taking linear combinations apply, but the resulting affine hull will be a higher dimensional shape such as a hyperplane or polyhedron.
  • Science Fiction and Fantasy Media
  • Linear and Abstract Algebra
