Air ballon and ball question. HELP
  • Thread starter Thread starter jmatta
    Air Ball
The discussion revolves around a physics problem involving a balloon ascending at 21.5 m/s and a ball thrown upwards at 13.2 m/s. Key points include the need to consider the balloon's upward velocity when calculating the ball's motion relative to the ground. The initial calculations for the time to reach the highest point and the height achieved by the ball were addressed, but there was confusion regarding the overall height off the ground and the ball's speed upon impact. The correct approach involves using relative motion principles and adjusting calculations based on the balloon's height at the moment of release. Understanding these concepts is crucial for accurately solving the problem.
jmatta
Air balloon and ball question. HELP!
A balloon is going straight up at 21.5 m/s. You are in the balloon and you throw a ball at 13.2 m/s straight up while riding in the balloon. If the ball hits the ground at 34.5s
a) How long oes it take the ball to stop once it leaves your hand at the ball's highest point?
b) How high did the ball go after leaving your hand? (from your hand to the highest point)
c) How high off the ground did the ball go?
d) How fast was the ball traveling when it hit the ground? (Not zero)
e) How high off the ground was the ball when it was released
Vavg=(x/t)
x=1/2 (Vi+Vf)t
a= (Vf-Vi)/t
Vf=Vi + at
Vf^2= Vi^2 + 2ax
X= Vi t + 1/2(at)^2
a=-g=-9.81
a) Vi= 13.2 m/s g=9.81 Vf= 0m/s t=?
t= (Vf-Vi)/a
t= (13.2-0)/9.81
t= 1.35 Seconds
b) x= 1/2 (Vi+Vf) t
x= 1/2 (13.2) 1.35
x= 8.88 m
c) Not sure yet
d) A guess
Vf= -9.81 (34.5) + 0
Vf= -338.445 m/s
e) no idea
Any help/corrections are appreciated to better my understanding. Thank you
You need to use the principle of relative motion to get the correct initial velocity. The velocity of the ball relative to the balloon is 13.2 m/s, but the balloon is also has a velocity...
Is there an equation for that? Are my initial answers wrong as far as the equations used i just have the values wrong?
Yes, the velocity's are simply added together to get the velocity of the ball relative to the ground or reference frame. From that point all the steps should be the same. Set your velocity final to 0m/s to find the time it takes to reach a peak. Use that time to calculate the height it reached. The only thing is there is some initial height when the ball is released (question E) and you only calculated the height it goes up from that release point. So you need to use the total time given to back calculate that initial height. Then use that total height (or just the initial height plus the initial velocity) to calculate the speed it would reach before hitting the ground (question C). So it seems as the questions are out of order, but that's how I'd do it.
