Air bearing for vibrostend platform
The discussion revolves around the feasibility of using an air bearing for a vibrating aluminum platform that must move strictly along one axis while tightly controlling movement in the Y and Z axes. The platform dimensions are 300x400x10 mm, with a maximum shift of 20 mm and a weight load of 6 kg, vibrating at frequencies between 0.5 and 1000 Hz. Concerns are raised about the challenges of maintaining stability and fixing the mass to the platform without metal membranes or brackets. The author concludes that an air bearing may be ideal for this application, despite the complexities revealed through resonance analysis and numerical calculations. Ultimately, a real prototype is deemed necessary to validate the design's effectiveness.
Pragman
Hi all!
There are actual task to specialists.
I have a problem. There is a platform. It made ​​of aluminum 300x400x10 mm and must moving strictly along one axis (for example X axle). The Y and Z axis of this platform should be very tightly held. We can not allow fluctuations of Y and Z!
Maximal shift along axis of the platform is 20 mm.
Weight load on the platform no more than 6 kg.
The platform must to vibrate along the axis with frequency from 0.5 to 1000 Hz.
Question: is it possible to solve a similar problem using the platform which is sliding on the air gap?
I want to giving up of all kinds of metal membranes, brackets, etc.
Is it justified?
Thank for attention!
Work out how much force you need, to oscillate a 6kg mass in simple harmonic motion with a peak to peak amplitude of 0.02m at 1 kHz.
Then decide for yourself whether a sliding air gap has any chance of being a good design for a bearing. (I think figuring out how to fix the mass to the platform would be quite a challenge, as well).
The absolute amplitude value of the platform shift is falling at the high frequency, but this is don't care for me.
Ok!
I found some moving platform types which are has been described as follows:
http://www.aerotech.com/product-catalog/stages/linear-stages/
http://www.dovermotion.com/StandardProductDetailPage.aspx?ID=112
I thinking finally that the air bearing scheme is ideally for my application.
The resonance analysis of metal membrane in the SolidWorks shows me many mechanical limitations. The numerical calculations of physical processes are difficulty, so only the real prototype model can to show real picture of result.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
