Can Oxygen Pass Through Water in a Suspended Tank?
In summary: So because the molecules of oxygen are not all moving at the same speed, occasionally an oxygen molecule with sufficient energy may strike the water over the hole with enough force to penetrate into the water. But there is an equal likelihood that an oxygen molecule will go the other direction (from the water, out the hole).
Idea04
194
I know with air bubbles in water that they will rise in water because they are lighter and less dense than water.
But if you had let's say a tank of water suspended in the air and at the bottom of the tank there were small holes so small that air can go through the holes but water couldn't.
Would the oxygen pass through the holes and rise in the water, or would the oxygen be blocked by the water molecules.
I kind of think that the water would not allow the air to move up because would the water want to move down words and since it couldn't the air will not flow. But I'm not sure on this.
Let the area of a hole = A. Consider a thin disk of water of area A and thickness ds. What is the total force on the thin disk of water covering the hole?
The forces are gravity (down) air pressure (up) and water pressure (down). (we will ignore surface tension).
The downward force consists of the weight of the column of water above the hole + downward air force (air pressure x A) on that column. The upward force is just the air pressure x A. You can see that the atmospheric pressures above and below cancel each other and you are left with the downward weight of the column of water. So which way does the water go?
AM
So if you went to a microscopic level and you had a hole the size of of an oxygen atom and at the bottom there was oxygen atoms and above were water molecules which are larger than oxygen. take in the account that molecule and atoms all have large space between them. Wouldn't some oxygen molecule be absorbed by the water.
In my previous answer I showed that the force required to lift a column of water covering the hole and insert an oxygen molecule is greater than the average force of impact of an oxygen molecule on the water (ie. the air pressure). Is there another way to get an oxygen molecule into the hole?
Because the molecules of oxygen are not all moving at the same speed, occasionally an oxygen molecule with sufficient energy may strike the water over the hole with enough force to penetrate into the water. But there is an equal likelihood that an oxygen molecule will go the other direction (from the water, out the hole).
AM
1. Can oxygen pass through water in a suspended tank?
Yes, oxygen can pass through water in a suspended tank through a process called diffusion.
2. How does oxygen diffuse through water in a suspended tank?
Oxygen diffuses through water in a suspended tank by moving from an area of high concentration (the air above the water) to an area of low concentration (the water). This process occurs due to the random movement of molecules.
3. What factors affect the rate of oxygen diffusion through water in a suspended tank?
The rate of oxygen diffusion through water in a suspended tank can be affected by temperature, pressure, and the concentration of oxygen in the air above the water. Higher temperatures and lower pressures can increase the rate of diffusion, while higher oxygen concentrations in the air will decrease the rate of diffusion.
4. Can oxygen diffusion through water in a suspended tank be increased?
Yes, the rate of oxygen diffusion through water in a suspended tank can be increased by increasing the surface area of the water, increasing the concentration of oxygen in the air above the water, or by agitating the water to disrupt the boundary layer that forms on the surface of the water, which can slow down the diffusion process.
5. Why is it important to understand oxygen diffusion through water in a suspended tank?
Understanding oxygen diffusion through water in a suspended tank is important for maintaining the health and well-being of aquatic organisms, as well as for various industrial processes such as wastewater treatment and aquaculture. It can also provide insights into the overall health and quality of the water in the tank.
  • Classical Physics
