Alpha-particle scattering experiment
In Rutherford's alpha-particle scattering experiment, using a thicker foil increases the likelihood of alpha-particles encountering atomic nuclei, leading to greater deflection angles and potential absorption. Higher-energy alpha-particles, however, have a larger velocity component perpendicular to the foil, which reduces deflection angles despite potentially increasing the number of particles that penetrate the foil. When substituting gold with silver, which has a lower atomic number, the weaker electric field results in decreased deflection angles due to a reduced coulombic force acting on the alpha-particles. The discussion highlights the complexities of particle interactions with varying material properties and energies. Understanding these factors is crucial for interpreting experimental results in nuclear physics.
MA103
I'm stuck with these questions. Please help if you can.
In Rutherford's experiment, alpha-particles were directed at a thin gold foil. A small fraction of the alpha-particles were back-scattered. Explain how this result would be affected if each of the following changes was (separately) made.
a) A thicker foil was used
b) Higher-energy alpha-particles were used.
c)A silver foil was used - the atomic number is less than that of gold.
c) is fine, I can do that. But a) and b) I seriously need help.
For a) I can thick of two things ...
1) alpha particles will get absorbed. If 1) is right, why is this?
2) because alpha particles will encounter more nucleus of more atoms, there will be more deflected alpha-particles.
For b) I have no idea. I'm guessing there will be more deflection but can't explain.
a) more back scattering
b) more particles getting through, less deflection
Hi, thanks but may I ask why for b)?
The \alpha-particles undergo hyperbolic trajectories when they pass nearby the positively charged gold nuclei. Increasing the thickness of the foil increases the probability of an \alpha-particle experiencing a close encounter with an Au nucleus resulting in greater deflection angles. Higher energy particles possesses a larger component of velocity perpendicular to the foil so I'd say the deflection angle is reduced. Silver has a lower molar mass than gold, the weaker electric field exerts a weaker coulombic force on the \alpha-particles resulting in decreased deflection angles.
Thanks for good explanation. :smile:
I'm the other way round, a) and b) i could do but c) i need help with!
What difference would it make if a silver foil was used instead of a gold one?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
