Can You Verify My Equations for Rocket Flight?
  • Thread starter Thread starter strive
    Altitude Rocket
The discussion centers on verifying a set of equations for rocket flight to calculate final altitude based on various parameters like fuel mass and thrust. The user is iterating calculations every second to determine vehicle velocity, acceleration, altitude, and mass, while acknowledging the challenge of approximating varying specific impulse and drag with altitude. Feedback suggests that the drag coefficients used may be too low, and it is recommended to utilize tools like OpenRocket and RASaero for more accurate simulations. Additionally, the user seeks condensed reading materials on supersonic aerodynamics for further understanding. The conversation highlights the importance of accurate drag coefficients in rocket flight modeling.
strive
Hi
I have written a set of equations for rocket flight (below) as i need to know the final altitude at various configurations (fuel mass/payload/exhaust mass flow/thrust).
I would ask if someone can please verify if this is correct (i have compared the results to results gained from Tsiolkovsky equation but it is difficult to approximate varying Isp with altitude and to include drag). Although the results are near.
I am calculating iteratively because i need to know the following parameters at 1 second intervals: vehicle velocity, acceleration, altitude and mass.
I know i should be using natural logarithm for mass ratios, but at 100 steps per second i postulated the error is negligible (a max error of 2% is allowed).
The equations in question are blue, the rest is just the programs structure (it's matlab/octave syntax).
Atmospheric conditions for each iteration are derived by a large number of equations which i have already verified thus i have not included them.m0=1100; % initial rocket mass [kg/s]
masso=500; % initial oxidator mass [kg]
massouto=6; % oxidator consumption [kg/s]
massoutg=1.5; % fuel consumption [kg/s]
massout=massouto+massoutg; % total propellant consumption [kg/s]
flightdur=(masso)/massouto % time of powered flight
t=0.01; % timestep
Rmax=0.826; % max vessel radius [m]
A=pi*Rmax^2; % max vessel cross-section [m2]
R=287; % air gas constant [J/kgK]
h0=0; % starting altitude [m]
T0=288.15; % temperature at 0m isa [K]
v0=0; % starting velocity [m/s]
g=9.81; % starting gravitational acceleration [m/s^2]
Cd1=0.015; % subsonic drag coefficient [/]
Cd2=0.04; % supersonic drag coefficient [/]
Xtotal=flightdur/t; % total number of timesteps [/]
% START CONDITIONS--------------------------------------------------------------
m=m0;
s=h0;
v=v0;
% TIMESTEP EQUATION BLOCK-------------------------------------------------------
for i=1:Xtotal
TIME=t*i;
%%% CALCULATION OF ATMOSPHERIC CONDITIONS (also defines vout)
(vout % exhaust gas velocity [m/s])
F=vout*massout; % generated thrust [N]
ro=p/(R*T); % ambient density [kg/m^3]
if v<340
Fd=A*v^2*ro*Cd1/2; % subsonic flight drag [N]
else
Fd=A*v^2*ro*Cd2/2; % supersonic drag [N]
end
Fu=F-Fd; % useful thrust [N]
dm=(massout*t); % mass change in timestep X [kg]
ma=m-(dm/2); % average mass during timestep X [kg]
a=(Fu/ma)-g; % acceleration in timestep X [m/s^2]
s=(a*(t^2)/2)+v*t+s; % altitude in timestep X [m]
v=(a*t)+v; % velocity at the end of timestep X [m/s]
m=m-dm; % vehicle mass at the end of timestep X [kg]
end
%%% COASTING PERIOD--------------------------------------------------------
ii=0;
while v>0
ii=ii+1;
TIMEcoasting=ii*t;
if v<340
else
end
a=-(Fd/massempty)-g; % acceleration in timestep X [m/s^2]
end
Thank you for your time
Perhaps you can use OpenRocket [1] to check your results. You may have to select "model rocketry" parameters for this to be accurate.
[1] http://openrocket.sourceforge.net
Those drag coefficients look perhaps an order of magnitude too low to me, and you'll lose a significant amount of accuracy by only having a subsonic and supersonic value, instead of a CD vs mach curve. If you want a more realistic aerodynamic simulation, RASaero is pretty good at estimating rocket drag all the way up to pretty high supersonic speed.
http://www.rasaero.com/
Thank you both.
I will test both programs.
I have checked the NACA RM A53D02 (from the RASAero site) now and it really seems the coefficients are way too low (i migth have used the planform area drag coefficients instead of frontal area drag coefficients).
By the way, can you perhaps guide me to some condensed reading on supersonic aerodynamics? I seem to be unable to find any »to the point« books.
Modern Compressible Flow: With Historical Perspective - J.D. Anderson
Elements of Gasdynamics - Liepmann and Roshko
Likes 1 person
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
