How Is Specific Gravity Calculated for a Submerged Aluminum Cylinder in Alcohol?
The discussion focuses on calculating the specific gravity of alcohol using an aluminum cylinder's weight and the volume of displaced alcohol. The aluminum cylinder weighs 1.01 N and displaces 3.88 × 10^-5 m³ of alcohol, resulting in an apparent weight of 0.778 N when submerged. The initial calculations mistakenly yielded the specific gravity of the cylinder instead of the alcohol. To find the specific gravity of the alcohol, the buoyant force, which equals the weight of the displaced alcohol, must be considered. By determining the mass of the displaced alcohol and dividing its average density by 1000, the specific gravity can be accurately calculated.
mikefitz
An aluminum cylinder weighs 1.01 N. When this same cylinder is completely submerged in alcohol, the volume of the displaced alcohol is 3.88 × 10-5 m3. The apparent weight of the cylinder when completely submerged is 0.778 N. What is the specific gravity of the alcohol?
m=W/g
m(cylinder)=.10296 kg
p=m/V
.10296kg/3.88*10^5 => 2653.608kg/m^3 (avg density)
SG= 2653.608/1000=> 2.65
What did I do wrong? Thanks
You found the specific gravity of the cylinder, not the alcohol. Hint: Buoyant force is involved.
Doc Al,
So I can find the mass of the alcohol, then the avg density, divide by 1000 and get the alcohol's SG?
Also, how do I relate Buoyant force to this problem? Thanks again
The force applied upwards by the alcohol is equal to the weight of the displaced alcohol
That'll work.
The buoyant force equals the weight of the displaced fluid (alcohol). You can find the buoyant force by comparing the actual weight of the cylinder to its apparent weight when submerged in the alcohol.
