Reacting Zn with .248M HCl to Produce H2
  • Thread starter Thread starter kippy
    Hcl
To determine the volume of 0.248 M HCl required to react with 1.36 g of zinc to produce hydrogen gas, first, calculate the moles of zinc using its molar mass (approximately 65.38 g/mol). This results in about 0.0208 moles of zinc. The reaction between zinc and hydrochloric acid is a 1:2 molar ratio, meaning 0.0208 moles of zinc will require 0.0416 moles of HCl. Using the molarity of the HCl solution, the volume needed can be calculated by rearranging the molarity equation (M = moles/volume) to find volume = moles/M. This results in approximately 168.5 mL of 0.248 M HCl needed for the reaction.
kippy
How many milliters of .248 M HCl are needed to react with 1.36g of zinc to produce hydrogen gas
Chemistry news on Phys.org
If you're stuck, you need to show what you've done till the point that you got stuck. Without that, we can not help in any way. Please read again, the posting guidelines for homework/textbook problems.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
