Ampere's Law: Determining magnetic fields of a shell conductor
A current of constant density, J0, flows through a long cylindrical conducting shell with inner radius a and outer radius b, prompting the need to determine the magnetic field in different regions. Using Ampere's Law, the magnetic field is found to be zero for r < a, B = μ0J0(r² - a²)/2r for a < r < b, and B = μ0J0(b² - a²)/2r for r > b. The discussion highlights the importance of understanding the relationship between current density and cross-sectional area to derive the enclosed current, ienc. The final expressions for the magnetic field in each region were confirmed to be correct. The problem-solving process emphasized the need to focus on cross-sectional area rather than volume for this scenario.
Renaldo
A current of constant density, J0, flows through a very long cylindrical conducting shell with inner radius a and outer radius b. What is the magnetic field in the regions r < a, a < r < b, and r > b? (Use any variable or symbol stated above along with the following as necessary: μ0.)
Ampere's Law
\oint B \bullet ds = μ0ienc
Solving for B:
B\oint ds = μ0ienc
B2∏r = μ0ienc
B = μ0ienc/2∏r
At r < a:
B = 0 because ienc at this point = 0
At a < r < b:
B = μ0ienc/2∏r
I don't know how to get ienc. I know it has something to do with the current density.
At r > b:
ienc = itotal, but I would need an expression for the volume of the cylinder.
V = ∏b2h - ∏a2h
V = ∏h(b2-a2)
Ienc = J0V \Rightarrow Ienc = J0∏h(b2-a2)
B = μ0ienc/2∏r
B = μ0J0h(b2-a2)/2r
However, by including h, I am introducing variables that the problem hasn't allowed me to use.
Ampere's Law
Solving for B:
B\oint ds = μ0ienc
B2∏r = μ0ienc
B = μ0ienc/2∏r
At r < a:
At a < r < b:
B = μ0ienc/2∏r
Current = current density times cross-sectional area. What is the cross-sectional area of your cylinder at a < r < b?
At r > b:
No. Volume does not enter the picture. Cross-section does.
That makes sense.
So at a < r < b:
B = μ0J0(r2-a2)/2r
At r > b:
B = μ0J0(b2-a2)/2r
That worked. Thanks for your help.
