Amplifier (non inverting) question
  • Thread starter Thread starter peanutbutter
    Amplifier
The discussion revolves around calculating the closed loop gain of a non-inverting amplifier with a negative feedback fraction of 0.5% and an open loop gain of 10^5, resulting in a closed loop gain of approximately 199.6. The amplifier is connected to a signal source with an internal resistance of 300 kohms and a 30 mV amplitude signal. The output voltage is analyzed under three conditions: open circuit, connected to an 8-ohm load, and connected to a 600-ohm load. The calculated output voltages are approximately 0.03 V for the open circuit, around 2 V for the 8-ohm load, and 0.06 V for the 600-ohm load, although the latter does not match the provided multiple-choice options. The thread seeks assistance in verifying these calculations and resolving the discrepancy with the options.
peanutbutter
An amplifier has negative feedback applied to it such that feedback fraction is 0.5%. If the open loops gain of the amplifier is 10^5 what is the closed loop gain? I get this as 199.6
The amplifier is connected to a signal source of internal resistance 300kohms which provides a sinusoidal signal of 30mV amplitude, when not loaded. If the amplifier has an input resistance of 150kohms and an output resistance of 600ohms what is the amplitude of the voltage signal that would appear at the output terminals of the amplifier when it is
a) open circuit
b) connected to a load resistance of 8 ohms
c) connected to a load resistance of 600 ohms
Gain of a non inverting amplifier = (R1+R2)/2
Any help would be great. It's multiple choice and the options are parts a,b and c are;
0.003V, 0.03V, 0.3V, 1V, 2V
Can anyone help?
a) open circuit
Gain of a non inverting amplifier = (R1+R2)/R2
a) open circuit, R1 = 0, R2 = infinity so gain is 1 ==> Vout = 0.03
b) Gain = (600+8)/8 = 76 => Vout is approximately 2
c) Gain = (600+600)/600 = 2 ==> Vout is 0.06 but there isn't an option for this. :S
Attempt
Could someone help?
I've shown my working.
