Transimpedance/Transconductance Amp: Low/High Rin & Rout, App Usage
  • Thread starter Thread starter peripatein
    Amplifiers
Transimpedance amplifiers require low input resistance (Rin) to ensure they do not affect the input current, behaving like an ideal ammeter, while their output resistance (Rout) also needs to be low to maintain output voltage integrity. Conversely, transconductance amplifiers need high Rin to avoid loading the input voltage, acting like an ideal voltmeter, and high Rout to ensure all output current flows through the load. The gain equations for both types highlight these requirements: transimpedance gain is based on voltage output per input current, while transconductance gain is based on output current per input voltage. Applications for current amplifiers include configurations like BJT common emitter amplifiers, which can effectively amplify current signals. Understanding these principles is crucial for designing effective amplifier circuits.
peripatein
Why do transimpedance and transconductance amplifiers have low Rin and Rout and high Rin and Rout, respectively? Also, I am having difficulties finding applications which require the use of current amplifiers.
I'd appreciate it if someone would kindly provide feedback on these three questions.
Transimpedance/ transresistance gain is express as this
Ar = Vout/Iin
As you can see the input signal for transimpedance amplifier is current. And this is why we want Rin = 0 ohm. Because only if Rin = 0 ohm our amplifier has no influence on input current. The input of our amplifier should behave like an ideal ammeter.
We have the same situation for the output signal. The output of a transimpedance amplifier should behave like an ideal voltage. And we can achieve that only if Rout = 0 ohm
Because for Rout larger than 0 ohm. The output voltage will drop if we connect the load. Vout = V* Rload/(Rout + Rload).
So only if Rout = 0, Vout = V.
https://www.physicsforums.com/threads/output-gain-of-2-stage-amp.696241/#post-4410720
As for transconductance amplifiers again the we have the same story.
The gain is Ag = Iout/Vin,
In this case the input signal is a voltage (input of our amplifier should behave like an ideal voltmeter), so only if Rin = ∞ amplifier do not have any effects on the input voltage. Amplifier do not load the input source.
But output signal is a current, so again only if Rout = ∞ all output current will flow through the Rload (current divider).
Iout = I * Rout/(Rour + Rload)
As for the current amplifier. What about BJT common emitter amplifier?
Thank you very much! :-)
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
