An electron is fired at a nonconducting infinite sheet
  • Thread starter Thread starter Mauve
    Electron Infinite
To solve for the electric field (E) and surface charge density (σ) related to an electron fired at a nonconducting infinite sheet, it's essential to understand the standard results for the electric field and potential of a uniformly charged sheet. If these concepts are not in your notes, deriving them through integration is necessary. The discussion emphasizes that basic knowledge of electromagnetism is assumed, and comprehensive teaching is not feasible in the forum. Clarification on the source of learning, whether from university or self-study, is also sought. Understanding these foundational principles is crucial for progressing in the problem.
Mauve
An electron initially 3.00 m from a nonconducting infinite sheet of uniformly distributed charge is fired toward the sheet. The electron has an initial speed of 420 m/s and travels along a line perpendicular to the sheet. When the electron has traveled 2.00 m, its velocity is instantaneously zero, and it then reverses its direction. What is the surface charge density on the sheet?
E = σ/(ε_0)
I've been thinking about this problem for some time now and think that I need to find E to solve for σ, but I have no idea how to go about that. How do I approach this problem?
Hint: motion represents kinetic energy.
That said, the field and potential for a uniformly charged sheet is a standard result. Are you sure you don't have it in your notes?
If not, you'll have to derive it through an integration process.
I'm sorry. I'm just unbelievably lost and don't know what you're talking about.
Okay, but we can only help you on here. We can't teach you electromagnetism from the beginning.
Where are you learning this? At university or on your own?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
