Analysis of Wall Crane: Force & Moment at Pins A & D
The discussion focuses on analyzing the forces and moments acting on a wall crane, specifically at pins A and D, under a load of 800 N. The tension in the cable at the winch W is determined to be 400 N, while the tension in rod BD is calculated to be 490 N. However, discrepancies arise when calculating the tension TBD using moments at pin A, resulting in a value of 2752 N. The participants emphasize the importance of correctly applying equilibrium equations and moment calculations to resolve these inconsistencies.
  • Understanding of Newton's Laws of Motion
  • Familiarity with the concept of equilibrium of forces
  • Ability to draw and interpret free body diagrams
  • Knowledge of moment calculations in static systems
  • Study the application of Newton's Laws of Motion in static equilibrium problems
  • Learn how to effectively draw and analyze free body diagrams
  • Research methods for calculating moments about different points in a system
  • Explore the principles of tension in cables and rods in structural mechanics
Engineering students, structural analysts, and professionals involved in mechanics and statics who need to understand force and moment analysis in static systems.
Harmony
The wall crane in Fig. 3 supports a load of 800 N. Determine the horizontal and vertical
components of reaction at the pins A and D. Also, what is the force in the cable at the winch
W?
[URL=http://imageshack.us][PLAIN]http://img182.imageshack.us/img182/992/tutorialse0.jpg[/URL] http://g.imageshack.us/g.php?h=182&i=tutorialse0.jpg [/PLAIN]
Newton's Laws of Motion, Moment, Equilibrium of Forces
First I draw a free body diagram at B. The vertical forces involved are the y component of the tension in rod BD and the y component of the tension of cable WB.
Since the tension of a massless cable is the same throughout the string, the tension of the cable is 400N. Substituting the value of TWB to the above equation, I get TBD=490N.
However, a problem occurs when I attempt to find TBD by taking the moment at A. The solution for TBD turns out to be 2752N.
What cause the difference in the answer?
I think it will be easier for us to see where you went wrong if you would show some work with regard to the step on substituting the value of Twb.
My suggestion to get Tbd, now that you have the tension in the rope right is to take the moments at A. The sum of moments must be zero. You have a 800N weight acting at 2 meters CW, and Tbw acting at 1 meter at a 60 degree angle CW. The counter moment CCW then must be Dx.
  • · Replies 23 ·
15K
12K
