Analytical chem lab and dilution factors
The discussion focuses on calculating the iron content in a vitamin pill through a series of dilutions and absorbance measurements. The initial solution contained 12.0 mg/L of iron after multiple dilutions, leading to confusion about the correct final concentration. A participant suggests that the original solution is 40 times stronger than the final sample, leading to a recalculated value of 4.8 mg of iron in the tablet. However, there is a debate about the importance of the dilution factors and how they affect the final calculations. Clarification is sought on whether the dilution from the initial 25 mL HCl to 250 mL should be included in the calculations.
tarzanna
Find the mg of Fe in vitamin pill. Vitamin pill was dissolved in 25mL HCl which was then diluted to 250mL with water in flask. 25mL of that solution was then diluted to 100mL in another flask. 10mL of the second was diluted to 100mL in another flask. Absorbance of the last solution and standard solutions were taken and a calibration curve created. It was determined that the sample solution contained 12.0mg/L iron. Determine the number of mg of Fe in tablet.
12.0mg/L x 0.100L x (100mL/25mL) x (100mL/10mL)=48.0mg Fe in tablet
I am not sure if I am correct. Do I need to account for the 25mL HCl diluted to 250mL as well?
Any help in direction would be greatly appreciated! Thanks.
25 mL (whole sample) ---> 250 mL Stock solution A
Stock solution A (25 mL) -----> 100 mL Stock solution B (1/4 as strong as A)
Stock solution B (10 mL) -----> 100 mL Sample solution (1/10 as strong as B)
Can you get there from here?
(your answer is not correct)
chemisttree: So, the original solution is 40x stronger than the sample solution. So if the sample solution contains 12.0 mg/L and total volume pipetted was 10 mL , is this the iron content of the tablet?
12.0 mg/L x 40 = 480 mg/L x 0.010L = 4.8 mg
Is this correct?
Thanks!
Is this correct?
Thanks!
Not yet!
Here is where you went wrong with your logic...
...and total volume pipetted was 10 mL ,...
Why is it important to know how much was pipetted from Stock solution B to the final Sample solution? You already used that information to determine that the Sample solution is 1/40 th as strong as the original solution which has the tablet's entire contents.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
