How Does a Particle Inside a Rolling Cylinder Affect Its Motion?
Azael
As in the attached picture.
A cylindrical shell with mass M can roll without gliding on a horizontal plane
In the cylindrical shell a particle ,p, with mass m can glide without friction.
At the beginning there is no motion and the angle to the particles position is \phi=\frac{\pi}{2}
I am suposed to find the movement of the center of the circle as a function of the angle \phi
Im not sure how I should start.
The potential energy of the system is, if I place the plane of reference on the level of the horizontal plane.
V=mgR(1-cos\phi)
Now this problem obviously only has one degree of freedom and that is the angle \phi
But if I want to construct a lagrangian I must use two degres of freedom. The rotation angle of the cylinder \alpha and the angle to the particle p \phi. Because I don't know how \alpha and \phi are connected. Is this the correct thinking?
In that manner I get this equation
L=T-V=\frac{3}{4}MR^2\dot{\alpha}^2+\frac{1}{2}m[\dot{\alpha}^2 R^2 + R^2\dot{\phi}^2 + \dot{\alpha}^2 R^2 sin\phi ] - mgR(1-cos\phi )
Should I use this and solve the two lagrande equations
\frac {d}{dt} \frac{dL}{d\dot{\alpha}}-\frac{dL}{d\alpha}=0
\frac {d}{dt} \frac{dL}{d\dot{\phi}}-\frac{dL}{d\phi}=0
Im not sure if this will give me any answere though? It feels like I should express \alpha in \phi before I even do the lagrangian. Am I on the right track?
I assume that I in the same manner can get the hamiltonian since its a conservative force situation and holonomic constrains.
H=T+V=\frac{3}{4}MR^2\dot{\alpha}^2+\frac{1}{2}m[\dot{\alpha}^2 R^2 + R^2\dot{\phi}^2 + \dot{\alpha}^2 R^2 sin\phi ] + mgR(1-cos\phi )
But I am not quite sure what I would do with that one either. I know that
\dot{\alpha}=\frac{dH}{dP_{\alpha}}
and
-\dot{P_{\alpha}}=\frac{dH}{d\alpha}
But that doesn't seem to be much help either??
I don't know...I wish I could help...
It seems like you really do need two generalized coordinates. I mean, the particle is free to move; it doesn't seem like it is constrained in any way such that \phi and \alpha would be related.
I think that there is an error in your Lagrangian: Since you are interested in the movement of the cylinder and watch it in the "labatory system", so to say, you can't say that the velocity of the particle in y-direction is R \dot \phi \cos(\phi). \phi is fixed in the "cylinder system", so you have you add the y-velocity of the cylinder. If you square this, you should get a "mixed term" so that the both velocities are related.
I managed to solve it. my expression for the Y position of the particle was
Rsin\phi + R\alpha
So velocity was
R\dot{\phi}cos\phi + R\dot{\alpha}
I used the fact that the conjugated momentum is constant for the alpha coordinate since there is no alpha, just alpha dot, dependence :) tricky problem.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
