And here i come again friction
  • Thread starter Thread starter afromanam
    Friction
The discussion revolves around solving two mechanics problems involving forces and friction. In the first problem, a momentum of 96 Nm is applied to a cylinder, and the minimum coefficient of friction (\mu_B) required for the ramp to move is calculated to be approximately 0.55518. However, inconsistencies arise when applying the equations, suggesting that the applied moment may not be sufficient to initiate movement. The second problem involves determining the minimum force required to move body B, with calculations indicating that the force P needed is 981 N, but there are complications in satisfying the equations simultaneously. Participants express frustration over the complexities of the problems while seeking clarity on their calculations and the role of friction in both scenarios.
afromanam
so now I'm undestanding a little bit more, but I'm still confused...
1) a momentum of 96 Nm is applied to the cylinder. The radius of the cylinder is 1 m. \mu_{A} = \mu_{C} = 0.25 The weight of the cylinder is 100 N. What is the minimum vale of \mu_B so the ramp moves to the right?. Weight of the ramp = 400 N. point B is the contact point between cylinder and the ramp.
My starting system of equations is:
96 \ N = F_{B} + F_{A}
Forces acting on the cylinder:
\sum{F_x} = -N_{B}\sin30 - F_{B}\cos30 + N_{A} = 0
\sum{F_y} = F_{A} + N_{B}\cos30 - F_{B}\sin30 - W_{cylinder} = 0
Forces acting on the ramp
\sum{F_x} = F_{B}\cos30 + N_{B}\sin30 - F_{C} = 0
\sum{F_y} = F_{B}\sin30 - N_{B}\cos30 +N_{C} - W_{ramp} = 0
From there, i go all the way to:
\mu_{B} = 0.55518
so far so good?, or I'm missing something? please refer to attachment 1
2) the body A 'weighs' 2500 kg. and body B 'weighs' 500 kg. \mu_{S} between A and B and between B and the ground is 0,2; and between A and the high surface is 0,5. Find the minimum required force P to start the movement of body B to right. Consider all the posibilities.
Ok, so when they say 'consider all the posibilities' i assumed that they meant that either x = z or x \neq z.
from there
forces acting on body A
\sum{F_X} = F_{A} = F_{C}
\sum{F_Y} = W_{A} = N_{A} + N_{C}
forces acting on body B
\sum{F_X} = P = F{_B} - F_{A}
\sum{F_Y} = N_{B} = N_{A} + W_{B}
\sum{M_{center \ of \ body \ A}}=\left\{\begin{array}{cc}N_{A} = N_{C},&amp;\mbox{ if }<br /> x = z\\\frac{N_{A}}{N_{C}} = \frac{d_{2}}{d_{1}}, &amp; \mbox{ if } x\neq z\end{array}\right.
\sum{M_{point \ A}}=\left\{\begin{array}{cc}\frac{W}{2} = N_{C} \ \mbox{(which, from previous balance of momentum)} = N_{A},&amp;\mbox{ if }<br /> x = z\\N_{C} = \frac{d_{1}W_{B}}{d_{1}+d_{2}}, N_{A} = \frac{d_{2}W_{B}}{d_{1} + d_{2}}&amp; \mbox{ if } x\neq z\end{array}\right.
so in both cases, i end up with P = 981 N, but as you can see \sum{F_X} of body A can not be satisfied if we were to satisfy also the \sum{M}, when x = z
3) I'm really growing fond of this Latex typesetting. I've seen quite a lot software for writing documents with Latex. which one do you recommend the most, for writing papers and/or a thesis?
thanks in advance for any help you can give me
\mu_{B} = 0.55518
I haven't looked at #2 yet. #1 still has me going. I thought I agreed with your equations, from which I deduced that point A is at the wall and point C is the floor. I found your result, based on a solution to the first 3 equations using the known coefficient at the wall. The result was
F_B = 58.24N
N_B = 105.49N
from which you might be inclined to conclude
\mu_B = \frac{F_B}{N_B} = 0.552
Unfortunately, those forces calculated from the first three equations are insufficient to move the ramp. If you plug them into the last 2 equations you will find that they are inconsistent.
This suggests that your first three equations are overspecifying the situation, and you cannot solve for the forces using just those three equations. Two ideas come to mind that need to be explored. The first is that the applied moment is simply not strong enough to move the ramp. Maybe the ramp is just too heavy (too much frictional force at the lower surface) to move it with a moment of 96Nm. The second is that the thing is moving as a result of the applied moment AND that it is accelerating. If the second condition holds then your first equation is not valid. You need to change it to represent an angular acceleration of the cylinder resulting from unbalanced moments, and relate that acceleration to the linear acceleration of the cylinder (downward) and the ramp (to the right). If there is acceleration, your first third and fourth equations all have to change.
I think the first thing to try is to allow the applied moment (M) to be a variable, assume no slipping at the ramp, and find the minimum M needed to move the ramp. If M must be greater than 96Nm, then there can be no movement of the ramp. If the minimum required M is less than 96Nm, then you know the ramp and cylinder are going to accelerate.
hello, olderdan
thanks for helping me out:
mhhh, i don't know if what i did is correct, but i added the \sum{F_X} in the cylinder and the \sum{F_X} in the ramp.
so we have:
N_{A} = F_{C}
and doing the same thing with \sum{F_Y} we have
F_{A} - W_{cylinder} - W_{ramp} + N_{C} = 0
so from there i get:
N_{C} = 470.58 \ F_{C} = 117.64 \ N_{A} = 117.64 \ F_{A} = 29.41 \ F_{B} = 66.59 \ N_{B} = 119.942 \ \mu_{B} = 0.55518
thanks for the help, let me continue working with your suggestions
afromanam said:
hello, olderdan
so we have:
N_{A} = F_{C}
That looks better than what I did. I'll see if I can reslove it with what I found, or see where I went wrong.
Edit:
I guess the problem is I can't do Algebra. I must have done the thing 5 times and kept making mistakes. My suspicions were correct however, to an extent. I finally wrote the matrix equation and let my calculator do it and reproduced your answer by solving only the first three equations. Those are sufficient for a solution for the "B" forces and their ratio. The reason my original answers were inconsistent with the last two equations is because they were inconsistent within themselves, and I did not check for that. When I got a ratio so close to yours I assumed you had done it the same way I did, which of course you had not. Now that I'm sure of the answer, I can to it by hand perfectly :rolleyes: . Sorry for the misdirection.
no problemo
hey, don't worry, even the best make some mistakes
what are your thoughts on number 2?
thanks for the help
from there
I think "all the possibilities" should put your focus on the relationship between d_1 and d_2. Your equation
\frac{N_A}{N_C} = \frac{d_2}{d_1}
or
N_C = \frac{d_1}{d_2}N_A
is valid as long as point A is to the left of center of Body A, which will always be true if it starts the left and the motion is gradual. Also
\sum{F_Y} = W_A = N_A + N_C
\sum{F_Y} = N_B = N_A + W_B
are valid all the time.
Two possibilities are that sliding occurs at point A before C, in which case
P = P_1 = 0.2 N_A + 0.2 N_B
OR sliding occurs at point C, in which case
P = P_2 = 0.5 N_C + 0.2 N_B
By the first ratio this is
P = P_2 = \frac{0.5d_1}{d_2}N_A + 0.2 N_B
If the first term in P_2 is smaller than the first term in P_1, then the slipping will occur at C.
Suppose the initial configuration favors slipping at A, which would be the case if d_1 &gt; 2d_2/5. The slipping results in a decrease in d_1 with no change in d_2 until the first term in P_2 becomes equal to the first term in P_1. On the other hand, if the initial configuaration favors slipping at C because d_1 &lt; 2d_2/5, d_2 will decrease with no change in d_1 until the first term in P_2 becomes equal to the first term in P_1. So what is going to happen when the distance ratio makes P_1 = P_2?
I happen to have Microsoft Word and MathType that allows LaTex conversion, so that is what I use when I do somethign more complicated. A lot of what I do is just reusing and editing what is here. I would have loved to have these tools when I was writing my thesis, which was to say the least a laborious process. I have not used any of the other software besides what I have.
i'm really desperate argh!
uhmm from what i understood, if P1 = P2 then sliding would ocurr in both surfaces when d1 = 0.4*d2.
you know i thought i had it, but nope...
MAN, it's frustrating, i really thought i had this one
please refer to attachments for diagram and fbd...
Weights: block A = 196.2 N (20 kg)
Beam BC = 245.25 N (25 kg).
The ramp in which block A lies is flat (i assume that means \mu_{between \ A \ and \ ramp} = 0)
\mu_{between \ Beam \ BC \ and \ block \ A} = 0.6)
the 'union' in C is simple and without friction. Calculate the force exerted over the beam in B.
ok, so i say 'oh, pretty easy, let's do the balance'
\sum{F_x} = -176.58(\frac{4}{5}) + N_{A}\frac{3}{5} + F_{BC}\frac{4}{5} - N_{BC}\frac{3}{5} = 0
\sum{F_y} = 176.58(\frac{3}{5}) + N_{A}\frac{4}{5} - F_{BC}\frac{3}{5} - N_{BC}\frac{4}{5} - W_{block \ A}= 0
and i get
N_{B} = 98.1 N
N_{A} = 255.06 N
and this satisfies the system above, but i was curios about 'then why was the beam weight given?' and i did a momentum sumatory in the beam, and the equation i got was:
\sum{M_C} = \frac{W}{2} = 0.6*N_{B}*\frac{3}{5} + N_{B}*\frac{4}{5}
and i get that N_{B} = 105.71
why?
i supposed that in C the union would exert a reaction, but still i got the same result because
\sum{M_B} = F_{Y \ in \ C} = \frac{W}{2}
and then F_{Y} - W + F_{B}\frac{3}{5} + N_{B}\frac{4}{5} = 0
so i got the same result again
that little difference... why does it ocurrs?
thanks again for your help, really, i appreciate it a lot
Let's think about this a bit more. It's fairly easy to see that if point A is sliding and point C is not sliding that Body A has no motion. To keep body A from moving to the right the force at C has to be equal to the friction force acting at point A, and has to be less than the maximum possible force at C. When d1 becomes equal to .04*d2, the maximum force at C is reached and Body A begins to slide at C. If the coefficients were constant and independent of motion, then these forces should be able to achieve a condition where they are both equal to their maximum possible values, both points would slide, and Body A would move steadily to the right at the speed necessary to maintain the d1/d2 ratio. This is consistent with your understanding of what would happen.
I don't think you need to incorporate this into your solution to the problem, but in reality the coefficient of kinetic friction is less than the coefficient of static friction, so what I think what would really happen is that if you start pushing Body B slowly to the right you would reach a point where sliding at C begins, which would suddenly reduce the frictional force at point C, making the frictional force at point A less than maximum and point A would stop sliding. When Body A has moved far enough to the right to increase the normal force at C (reducing the normal at A) point C would stop sliding and A would start sliding again. I think the motion would actually be a series of steps with alternate sliding at points A and C.
I think I see the problem you are having with the new one. It appears that you solved the first two equations assuming the block is moving so that
F_{BC} = 0.6*N_{BC}
and used that relationship to reduce the first two equations to 2 unknowns, then solved for them. Now you find the result is inconsistent with the equation for the beam. This is similar to what I did on that other problem, except that in that case there was motion and I had just made an algebra mistake. In this case, the applied force really is insufficient to make the block move. Assume you do not know the ratio of the frictional to normal force at B, and solve all three equations simultaneously. You will find larger values for the normal forces, and the ratio of the forces at B will be less than 0.6. Your last equation needs to be rewritten as
\sum{M_C} = \frac{W}{2} = F_{BC}\frac{3}{5} + N_{BC}\frac{4}{5}
I'm not sure what you were asked to find, but your result will show that the net force on the beam at B is not vertical and leans to the right. That means the reaction at C has to lean to the left. Your last equation is justified if you can assume the horizontal component at C is applied to the lower right corner of the beam. If it were applied at the center or the top, you would have to include the moment due to the horizontal components of the forces at B. Since the thickness of the beam is not specified, and the details of the support at C are not apparent, then I think your equation is OK. If there are details you have not included, then you need to consider the beam more carefully.
oops, data missing
yes, i was asked to find the force exerted by the block on the beam at point B.
