Angular momentum and oscillation of disk
A solid disk of mass M and radius R is mounted on a fixed axis, and a small projectile of mass m_1 collides tangentially, causing the disk to rotate and oscillate. The discussion focuses on calculating the maximum angle of rotation (theta_max) and the frequency of oscillation under the assumption that theta_max is small. The approach involves using conservation of momentum and energy to find the height at which the projectile stops, which relates to the maximum angle of rotation. Additionally, the appropriate equations of motion are needed to derive the expression for frequency. Understanding these concepts is crucial for solving the problem effectively.
jonnyboy
[SOLVED] Angular momentum and oscillation of disk
A large solid disk of mass M and radius R is mounted on a fixed axis through its center using ideal bearings. A small projectile of mass m_1 traveling with velocity v_1 collides tangentially to the slight extension and sticks to the larger disk causing it to rotate about its center and oscillate
a. Determine the maximum angle the disk will rotate (theta_max)
b. Determine the frequency of oscillation ( assume theta_max is small enough so that the angle approximation is valid)
If someone would know what steps I need to take or where to start would be a great help.
When the mass m1 with some momentum and kinetic energy impacts the disk of mass M, the disk will rotate to some angle at which the smaller mass is at some height (change in potential energy) where the rotation stops. Then the disk will rotate in the opposite direction, and oscillate.
So one has to determine by that appropriate conservation equation(s), the height at which m1 stops, and related that to the maximum angle of rotation.
Then one must determine the appropriate equation of motion from which one will obtain an expression for frequency.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
