Angular momentum - can you start spinning while falling?
When a person drops straight down from a rope, she cannot initiate spinning while falling due to the conservation of angular momentum, as her initial angular momentum is zero. Curling into a ball does not create angular velocity unless an external torque is applied, which is not possible in free fall. The discussion also touches on the difficulty of performing sit-ups with hands behind the head, linking it to increased moment of inertia. A higher moment of inertia requires more torque to initiate movement, making the exercise more challenging. Overall, both scenarios illustrate the principles of angular momentum and moment of inertia in motion.
hatingphysics
-- A person is hanging motionless from a vertical rop over a swimming pool. She let's go of the rope and drops straight down. After letting go, is it possible for her to curl into a ball and start spinning? Justify your answer....is there going to be angular velocity? will that allow her to spin?
-- Sit-ups are more difficult to do with your hands placed behind your head instead of on your stomach. Why?...does it have to do with moment of inertia? if not i have no idea where to go from here?!
hatingphysics said:
-- A person is hanging motionless from a vertical rop over a swimming pool. She let's go of the rope and drops straight down. After letting go, is it possible for her to curl into a ball and start spinning? Justify your answer....is there going to be angular velocity? will that allow her to spin?assuming no air, what do you know about the conservation of angular momentum principle? What is her initial angular momentum? Can she apply a torque to start rotating?[/color]
-- Sit-ups are more difficult to do with your hands placed behind your head instead of on your stomach. Why?...does it have to do with moment of inertia? if not i have no idea where to go from here?!Is the persons rotational inertia greater with her arms on her head? Why or why not? What does that say about the torque she must apply to start her rotation about the waist?[/color]
See comments in red above.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
