Angular Momentum Prob: Find Wfinal & Angle
Idoubt
http://img156.imageshack.us/img156/3485/jamqs.jpg
Uploaded with ImageShack.us
w= ang velocity
L= ang momentum
I = moment of inertia
r cross F = torque
moment of inertia of a horizontal square surface = 1/6 m a2
The time taken should not depend on the rotation and should simply be a/v
http://img853.imageshack.us/img853/4941/74506532.jpg
Assuming the angle above, the torque the man applies on the square should be independent of the rotation on the square and should only depend on the position of the man on the side of the square. Then from the geometry, the torque is
r*F = rFcos(theta) but r = (a/2)/ cos theta
then Torque = (a/2)F = (a/2)md2r/dt2
Integrating ang momentum L = [( ma/2) (dr/dt)]
Now the velocity of the man with respect to the platform, V = dr/dt - rw
so dr/dt = v+rw
sub in ang momentum eq, I get,
L = Iw = mav/2 + marw/2
at t = a/v, r is the diagonal = a/(2)1/2
so Lfinal = 1/6ma2wfinal=mav/2 + ma2w/2(2)1/2
then wfinal = V/((1/3)-1/(2)1/2))a
this is as far as I got, I get this nagging feeling that I have over thought this and made unnecessary complications, and also I can't integrate this Wfinal to get the angle since its not a function of time, just the final ang velocity. also not sure how to get r as a function of time, pls tell me what I am doing ( or thinking ) wrong.
Hmm now it occurs to me that if he has applying a force on the platform, he can't possibly walk with a constant velocity, so there must be an initial force, but after that there can be no net force over time. so his ang momentum must be constant? :cry:
Thinking of this prob with constant angular momentum,
L = Iw = r*P = r*mv = rmvcos(theta)again, r = a/2cos(theta) then, Iw = 1/6ma2w = amv/2
then w = 3v/a,
integrating, theta = 3vt/a
at t = a/v, theta = 3 radians, I think it should be = -3 rad, with my sign convension,I'm not so sure about rt,
My best guess is,
Wman measured from space = Wman from platform - Wplatform
Here Wplatform was the w that we solved earlier
then, Vt/rt = V/rt - Wp
since, r is the same in both frames.
so, Vt + rtWp = V
diff w.r.t time,
d2r/dt2 + Wpdr/dt = 0
This is the S.H.M D.E, with soln,
rt = Acos ( (Wp)1/2t + phase angle)
here A has to be the max value of r, ie the diagonal of the square a/(2)1/2So rt = a/(2)1/2cos ((Wp)1/2t + phase angle)Can some1 tell me if I'm even close?
And my best guess is very very wrong :smile: that's not the S.H.M Diff eqn, if i solve that equation, i get an exponent in my soln and that can't be right, I'm sure rt has to be a sin or cos function.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
